Kioti CK30 Kubota 3030HSDC
   / Kioti CK30 Kubota 3030HSDC #21
72" is actually easier because you can drive right over it. I have a 60" so I have to raise the front end which is easily done with the fel. One of the rear casters is turned and locked in place so with the front 2 casters you can roll the unit around. I didn't like that so I welded up a dolly that slides under the rear of the deck giving me swivel wheels on all 4 corners so it is very simple for me to roll the deck anywhere. Drive shaft is a simple snap coupling, front mount is a lever that the front bar mounts into and rear is 2 spring loaded pins. Have the dealer show you; it's simple and strudy. The other nice thing about the mmm is the edge of the deck is very visible from the cab when you're trimming. Again, if I was brush cutting I'd want it on the 3pt for the reason you stated but for reg. mowing, I like underneath.
   / Kioti CK30 Kubota 3030HSDC #22
Munchie: see you're getting a blower also. I welded up the same kind of dollies for the carrier and front blower and it makes that job a no brainer too.
Thx forester...good info
Kubota Salt-Spreader (A52384)
Kubota...
2014 Chevrolet Silverado 1500 Pickup Truck (A51692)
2014 Chevrolet...
NEW Woods Reverse Rotation 5ft Tiller (A52748)
NEW Woods Reverse...
2008 JLG 450AJ SERIES II MANLIFT (A51246)
2008 JLG 450AJ...
2018 Nissan Titan Pickup Truck, VIN # 1N6AA1E57JN515039 (A51572)
2018 Nissan Titan...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
