Kioti CK3520SE vs TYM (Branson) 3620H
   / Kioti CK3520SE vs TYM (Branson) 3620H #1
bomberodevil
Kioti CK3510 HST
Advice for purchasing (long!)
Hi folks, I’m asking for a little advice. I’m close to pulling the trigger on a new compact tractor, and I’m down to the KIOTI CK3520SE and the TYM (Branson) 3620H.
I’m a new tractor owner, but pretty handy with equipment. I do my own maintenance on my vehicles, and plan to perform the maintenance on the tractor. My land is 10 acres in southwest Michigan, and I will be mainly finish mowing 2-3 acres, clearing some smaller trees and shrubs, and maintaining about 700’ rock driveway. The soil is sandy top soil, not many rocks, and I may be doing some snow removal, but not a lot of snow.
The implements I plan on buying and using will be a finish mower, grapple, some FEL work, land plane, and maybe a brush hog 1-2 a year. Both dealers are less than 30 miles away, both are family owned, both are nice people, both have been carrying their brands for years, and both have full shops for warranty work.
The pluses of the Kioti are-
Smaller size for more accessible
Work station seems more open
Long list of standard equipment with the SE model
Can get R14 tires if I want them (do I?)
The minuses of the Kioti are-
Lighter weight-2921 lbs
Fuel tank up higher, have to wrestle five gallon tank for refueling.
The pluses of the TYM are-
Much heavier-3754 lbs (too heavy?)
4 speed HST, higher top speed (but will rarely be on a road)
Fuel tank lower, easier to refill
The minuses of the TYM are
Work platform seems a bit smaller, but not unworkable
Merger of TYM and Branson, will the Branson 3620H be around in a couple more years?
Parts and dealer network for TYM seems less than Kioti
I really appreciate the knowledge and experience of the folks on this group, and I’d appreciate any feedback On these two tractors. Please try to limit comments to these models, as I’m pretty comfortable with these two. Thanks!
   / Kioti CK3520SE vs TYM (Branson) 3620H #2
The Branson is a TYM, so parts shouldn't be an issue.
   / Kioti CK3520SE vs TYM (Branson) 3620H #3
The Branson/TYM xx20 series is more comparable to the Kioti DK series. While the Branson/TYM xx15 series is more comparable to the Kioti CK series.
Honestly, both great machines, but nothing like going to check them out in place and better yet, sit in both machines, get a feel for it and see which one you fit better and how you like the controls.
Between the Branson built models vs TYM built models, I much prefer the Branson built ones.
   / Kioti CK3520SE vs TYM (Branson) 3620H #4
Have you sat in both? I find the 3620 quite a bit more roomy than the Ck3520. It’s a frame size bigger. I’d steer toward the TYM. Finishing mowing maybe better on the Kioti, but about everything else the TYM would have an advanatge.
   / Kioti CK3520SE vs TYM (Branson) 3620H #5
@ptsg hit the nail on the head; a more direct comparison would be the Kioti DK-20 and TYM 20 series, or Kioti CK-20 and TYM 15 series.
I did sit in both, it just seemed to be a bit more “contouring” around to get into the 3620 seat. Once in the seat, it was roomy enough. I’m old, 250 lbs, with 8 knee surgeries! I’m no Gumby anymore! 🤣🤣
   / Kioti CK3520SE vs TYM (Branson) 3620H #7
So I re-read your post; what has you settled on these two? They're quite different.
I've got a CK myself, a 2610, and it's a great little tractor. Excellent hydraulics; however, the TYM would naturally be superior in that regard, it's a larger machine.
I was looking at the CK3520 and the TYM 3515, and there was a 3620 for roughly the same price as the Kioti CK3520. My impression as a tractor novice was the Kioti is fairly refined with a lot of features, but the TYM 3620 is just beefier as far as frame and weight goes. I’m also looking for gently used 2021-2023 models of the same or close equivalents
   / Kioti CK3520SE vs TYM (Branson) 3620H #9
I mean if you're going on specs, a 20 series TYM will out work a Kioti CK all day long; the TYM is a larger frame size, and therefore a more capable machine. The only way the two will compare is on PTO horsepower.
   / Kioti CK3520SE vs TYM (Branson) 3620H #10
My thought would be if you're going to go up to the 20 series chassis size, 35 engine hp and 29 pto hp will likely not be enough to run the size attachments you'll be looking at in that sized frame. Also, from memory, some of the guys who bought the 3620 have said that it doesn't really have enough hp to run it down the road in it's highest range (4 speed hydro).
You've only listed a finish mower and a brush cutter as possible pto driven attachments. Anything else? Wood chipper? Tiller?
That 20 series is going to "want" a 6 foot wide attachment to cover it's larger chassis width. I do run a 6' brush cutter on 32 pto hp myself, and it'll work. But there are times that it's all my machine wants. I'm not a "speed racer" type operator when I'm mowing, as most fields I'm in are new to me and are very heavily overgrown. So I have to go at a quick walking pace due to not being able to see the ground in front of me (too thick).
For driveway work and grapple work, the hp won't really matter. It's all tractor weight and hydraulic lift (both 3 pt and FEL).
If you like the 20 series, I would look at the 4820. Same machine size and lift specs, but more pto hp to work with.
For me (different uses), if I was buying today, I would be looking very hard at a cabbed 5520 with 3rd function and at least 2 rear remotes.
Pallet Fork Frame (A47371)
Pallet Fork Frame...
Erskin Post Hole Digger (A49251)
Erskin Post Hole...
45022 (A48082)
45022 (A48082)
2015 Nissan Altima Sedan (A46684)
2015 Nissan Altima...
LOAD OUT AND SHIPPING (A48837)
LOAD OUT AND...
2015 KENWORTH T800 (INOPERABLE) (A48992)
2015 KENWORTH T800...
