Westside123
- Joined
- Jan 22, 2024
- Messages
- 7
- Tractor
- 2014 kioti 2410
Good day,
I decided to change the oil on the front differential. Followed the instructions in owners manual. Seemed pretty straight forward. Does it take a while for the oil to make it over to the opposite side of the fill plug? I was told that when filling with new oil, unplug drain on opposite side and do a quIck check to see if new oil is draining out. I’m glad I did as there was no oil coming out of drain and the fill side was getting pretty high with oil. I took it for a drive and going to let it sit for a while and see if the level drops. when removing the old oil, I let it sit for about an hour so I’m not to sure what’s causing the issue. Thanks in advance!!
