J_J
Super Star Member
- Joined
- Sep 6, 2003
- Messages
- 18,973
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
The float assembly #11 will not cause your leak. It is on the outside of the valve.
If your spool has o-rings, they might be leaking. They would be replaceable.
If you remove everything from the bottom of the spool, you can pull the spool out of the valve.
What is on the bottom of the valve is the spool centering springs and retainers, and then the float assembly. .
