Kioti DK55 Hydraulic warning light coming on.
   / Kioti DK55 Hydraulic warning light coming on. #1
Unouwood
Kioti DK55
Have a 2003 DK55. Hydraulic warning light comes on after driving or operating cutter for a short time. Changed Hydraulic filter. Will check sensors next. Anyone experience this ? Ideas ? Thanks
   / Kioti DK55 Hydraulic warning light coming on. #2
My DK45 did that a few years back. I believe it was a faulty temp sensor. I believe the system works by closing the temp sensor at 140 degrees and then monitors for excessive vacuum at the filter. Works that way to monitor the hydraulics but not turn on the light with cold oil.
   / Kioti DK55 Hydraulic warning light coming on. #3
i have a 2003 dk40 which does this as well when brush hogging. Randy are you saying it is not an issue or is it a high temp warning?
2018 Bomag BW120 SL Tandem Vibratory Smooth Drum Roller (A56857)
2018 Bomag BW120...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
1998 6.5x16 Anderson Utility Trailer (A56859)
1998 6.5x16...
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
2012 Ford Transit Connect Cargo Van (A56858)
2012 Ford Transit...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
