Kioti lk3054 steering column
   / Kioti lk3054 steering column #11
I can definitively say that no oil should be in the column. Tore mine LK column down to the pump today and found- dust seal on top of column, rubber bushing below that a 1'2" or so, threaded portion in middle of column with no seal, and a lower oil seal on top of the pump, directly above a needle bearing. Lower seal was barely identifiable as a seal, and allowed oil from the pump to move up the column to the upper dust seal, inside of column contained all sorts of goop(rubber/water/oil mixture), steering shaft was moderately corroded and required sandblasting, upper bush was intact but way oversize on inner bore, and the new dust seal I installed a few months back ruined from the shaft slop. Had to utilize drawings from an LK 3504/LK3054/LK2554, to build a complete picture of what was actually in there, and even then it lacked a bit of detail. Probably 100 bucks in parts to complete from pump on up. Waiting on parts now.....
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
2018 CATERPILLAR 930M WHEEL LOADER (A60429)
2018 CATERPILLAR...
2000 CATERPILLAR 988F WHEEL LOADER (A60429)
2000 CATERPILLAR...
1985 Ford Ltl9000 Tender Truck (A56438)
1985 Ford Ltl9000...
iDrive TDS-2010H...
