Kioti metric hydraulic adapters
   / Kioti metric hydraulic adapters #1
dfkrug
Super Member
Santa Cruz Mtns, CA
05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
I need metric adapters for a Kioti 2375 backhoe and a KL130
loader. Does anyone know the size for the hose connection to
the hydraulic cylinders? How about a source, too? I want to
connect my pressure test guage to the hose end at the cylinder,
and I want to adapt same to a hydraulic PHD. My usual online
adapter supplier carries no metrics.
   / Kioti metric hydraulic adapters #2
They don't use any metric on hyd fittings.... they are all standard..... Should be able to get them at any auto parts store or farm store that sells hydraulics...
I keep quite a collection of JIC, SAE ORB, and NPT hyd fittings and
the Kioti is close to a 3/8 JIC, but the thread is different and the
diameter is just off. Have you actually tried connecting a Kioti hose
to a JIC or NPT adapter?
   / Kioti metric hydraulic adapters #4
When you say 3/8" JIC do you mean a #3 JIC which actually has 3/8" - 24 straight threads or do you mean something else? A 3/8" pipe thread (straight or tapered) will have 18 threads per inch and will actually have an outside diameter of .67 inches while the JIC will be a true 3/8" (.37"). Confusing?? :confused: :confused: Yes.
Measure the thread diameter and # of threads per inch. Any machinist handbook will have cross references so you can see exactly what you got.
   / Kioti metric hydraulic adapters #5
They used #5 JIC fittings on my CK20 loader valve, #6 ORB male to #5 JIC male on the loader valve. The hose has #5 JIC females on each end. Then they tried to make a bulkhead out of a #5 JIC male by 3/8" NPT male thru a plate sandwiched by two washers on one side and one on the other into 3/8" female quick connects ( this is where the loader QD's hook up). Make sense?
Steve
   / Kioti metric hydraulic adapters #6
For future reference, a #5 JIC is a true 1/2"-20 thread. A #6 ORB (or a #6 JIC or an SAE 6) is a true 9/16"-18 thread. Remember hose size has nothing to do with fitting size.
Steve_Miller said:
They used #5 JIC fittings ......
Steve
It is indeed 1/2-20 threads, so #5 JIC (5/16) it is. Unusual size.
All other tractors and hyd eqp I have had used #4s, #6s, #8s, #10s.
No #5s. I also noticed the thread-thread diameter of the fitting
on the cylinder is slighty less than 1/2", so I was guessing it was
M12 x 1.00. The diameter is also a little less than the common
1/2-13 bolts I have lying around...
Thanks Steve and Mad!
-Dave
   / Kioti metric hydraulic adapters #8
I don't know how many times I've told my wife this:D
2015 Ford E-350 Cutaway Box Truck (A55973)
2015 Ford E-350...
Voltage Converter, Single Phase, 240 Volt Input, 120 Volt Output (A59076)
Voltage Converter...
2017 GMC SIERRA 1500 (A58214)
2017 GMC SIERRA...
2004 Timber King TK350 Wheeled Feller Buncher (A59213)
2004 Timber King...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
PALLET OF 11 BARBED WIRE ROLLS (A58216)
PALLET OF 11...
