Kioti metric hydraulic adapters
   / Kioti metric hydraulic adapters #1
dfkrug
Super Member
Santa Cruz Mtns, CA
05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
I need metric adapters for a Kioti 2375 backhoe and a KL130
loader. Does anyone know the size for the hose connection to
the hydraulic cylinders? How about a source, too? I want to
connect my pressure test guage to the hose end at the cylinder,
and I want to adapt same to a hydraulic PHD. My usual online
adapter supplier carries no metrics.
   / Kioti metric hydraulic adapters #2
They don't use any metric on hyd fittings.... they are all standard..... Should be able to get them at any auto parts store or farm store that sells hydraulics...
I keep quite a collection of JIC, SAE ORB, and NPT hyd fittings and
the Kioti is close to a 3/8 JIC, but the thread is different and the
diameter is just off. Have you actually tried connecting a Kioti hose
to a JIC or NPT adapter?
   / Kioti metric hydraulic adapters #4
When you say 3/8" JIC do you mean a #3 JIC which actually has 3/8" - 24 straight threads or do you mean something else? A 3/8" pipe thread (straight or tapered) will have 18 threads per inch and will actually have an outside diameter of .67 inches while the JIC will be a true 3/8" (.37"). Confusing?? :confused: :confused: Yes.
Measure the thread diameter and # of threads per inch. Any machinist handbook will have cross references so you can see exactly what you got.
   / Kioti metric hydraulic adapters #5
They used #5 JIC fittings on my CK20 loader valve, #6 ORB male to #5 JIC male on the loader valve. The hose has #5 JIC females on each end. Then they tried to make a bulkhead out of a #5 JIC male by 3/8" NPT male thru a plate sandwiched by two washers on one side and one on the other into 3/8" female quick connects ( this is where the loader QD's hook up). Make sense?
Steve
   / Kioti metric hydraulic adapters #6
For future reference, a #5 JIC is a true 1/2"-20 thread. A #6 ORB (or a #6 JIC or an SAE 6) is a true 9/16"-18 thread. Remember hose size has nothing to do with fitting size.
Steve_Miller said:
They used #5 JIC fittings ......
Steve
It is indeed 1/2-20 threads, so #5 JIC (5/16) it is. Unusual size.
All other tractors and hyd eqp I have had used #4s, #6s, #8s, #10s.
No #5s. I also noticed the thread-thread diameter of the fitting
on the cylinder is slighty less than 1/2", so I was guessing it was
M12 x 1.00. The diameter is also a little less than the common
1/2-13 bolts I have lying around...
Thanks Steve and Mad!
-Dave
   / Kioti metric hydraulic adapters #8
I don't know how many times I've told my wife this:D
Giyi Excavator 44" Rake (A57149)
Giyi Excavator 44"...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2005 KOMATSU GALEO D39PX-21 CRAWLER DOZER (A52709)
2005 KOMATSU GALEO...
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58216)
2019 LOAD TRAIL...
Toyota LPG 7FGCU20 3,400 lb. Capacity Forklift, S/N 86163, Dual Mast, Tilt, 80" Reach, 19,871 Hours (A59076)
Toyota LPG 7FGCU20...
