IH3444
Elite Member
- Joined
- Jan 10, 2004
- Messages
- 2,552
Pilot bushings are easy. Just find a tap which is just a little larger than the hole for the shaft inside the bushing. As you crank the tap in with oil, allow it to bottom out. It will then begin to crank the pilot bushing out. After the bushing is out, remove the bushing from tap. Inspect hole first, and besure that the tap has a base to bottom out. You can place a smaller nut in before the tap, to keep from maring your shaft hole bottom with the tap.
