Kohler vs Kawasaki fuel consumption
   / Kohler vs Kawasaki fuel consumption #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
For the last 10 years I have had a Scag wildcat, 61" deck, and Kohler command pro 27 (27hp). Mower is about 15 years old.
Dad has a nearly identical zero turn. Bobcat flavor, zt223 model. 61" cut, 23hp Kawasaki, also about 15 years old.
I mow about 4-1/2 acres. Takes me exactly 2 hours to mow. I use just a tad over 4 gallons of fuel. My mower has a 5 gal tank on right, and 4 gallon on left. I cannot mow it ALL starting on the left tank. I have to switch and go another 10-15 min. So....as I said, a tad over 4 gallons.
Today I mowed with dads mower because he has a bagger and want the clippings for the garden. Bagger slows things down, but I also mowed his 3-ish acres too. He has dual 5 gallon tanks that I filled before I started. Took me 5-1/2 hours to mow his AND mine. Only idling down for the few minutes it takes to empty the bagger when needed. I mowed for 5 hours straight before I had to switch tanks.
So.....my Kohler 27hp....guzzles a little over 2 gallons an hour. While his 23hp Kawasaki sips right at a gallon per hour. Sure wouldnt think the slight (and un-noticable) difference in HP would make that big of a difference
So, what mowers/engines do you all have, and how are they on fuel in terms of gal/hr?
Both are carb btw, no fancy fuel injection like modern stuff
   / Kohler vs Kawasaki fuel consumption #2
2013 Hustler Super Z zero turn mower.
72" deck, 35 HP Kawasaki FX1000 carbureted. Uses close to 2 gallon per hour.
   / Kohler vs Kawasaki fuel consumption #3
My Toro groundsmaster has a Kawi 25hp with two tanks, the two tanks go down evenly, it sips fuel compared to any Kohler or BS I have ever had..
Ever get a ballpark gph on your usage?
   / Kohler vs Kawasaki fuel consumption #5
2 gph, OUCH. That makes me appreciate my Kubota diesel more. My previous 25 hp Kohler burned around 1 gph. My diesel mower burns 1/2 gph or maybe a tad more but it’s doing more work than the gasser.
   / Kohler vs Kawasaki fuel consumption #6
My 2001 model year Power Trac PT425 has a Kohler Command 25hp engine in it. I almost always run it full out at 3600rpm. I consistently use just over 1 gallon per hour, so I'm gonna say 1.2 gallons per hour to keep it honest. ;)
The motor turns 3 hydraulic pumps that power 4 wheel motors and any implements, like my 60" finish mower and 48" brush cutter. I get about the same fuel usage regardless of running those powered attachments or just using a bucket on the FEL.
I am asking because it makes me wonder if something is wrong it if it's just the way Kohler is. Runs good, not like it's running rich or anything. Good mower, just thirsty as all get out
   / Kohler vs Kawasaki fuel consumption #9
I think there’s something wrong. I’ve never heard of fuel usage that high in that hp class. And my 25 hp kohler burns about half that much.
   / Kohler vs Kawasaki fuel consumption #10
My Grasshopper, 25 hp Kubota diesel, 61" deck burns very close to 1/2 gallon an hour, depending on how tall the grass is.
IF, I mowed the grass more often, it would use even less fuel, but that never seems to happen...
BTW, EVERY Kohler motor I have ever owned, was thirsty!
SR
2025 Kivel 48in Forks and Frame Tractor Loader Attachment (A46683)
2025 Kivel 48in...
2009 TRAIL KING PNEUMATIC TRAILER (A45333)
2009 TRAIL KING...
2016 W.W.Trailer All Around Aluminum 16ft T/A Livestock Trailer (A45336)
2016 W.W.Trailer...
3000 Gallon Black Poly Water Tank (A45336)
3000 Gallon Black...
2005 INTERNATIONAL 7600 REAR LOAD TANDEM AXLE GARBAGE TRUCK (A45676)
2005 INTERNATIONAL...
2025 Swict 66in Bucket Skid Steer Attachment (A46683)
2025 Swict 66in...
