Kontak Spool Valve rotary control knob
   / Kontak Spool Valve rotary control knob #1
Keycare
Swansea, UK
Massey Ferguson MF250
I wondered what it is for...
I removed the valve assembly to add a third slice. The existing two slices control a FEL, the first is for a single acting ram (lift) and the second is for the double acting ram (curl).
Each slice has a rotary control as well as the lever but I don't know what it does, I was told that it may allow the valve to be switched between double acting and single acting operation but I don't know if that is true or which way to turn the knob for which setting.
There is no power beyond connector and the tractor (MF250) has open centre hydraulics, so I am concerned that the setting of these rotary knobs is important.
In the picture there are extension rods on the lever and rotary knob.
Any help appreciated.
Rich.
   / Kontak Spool Valve rotary control knob #2
The knobs are flow controls "usually" for closed center systems. About 2 hours ago I converted a closed center Kontak valve to open center. If you are going to run it in a open system, run the flow control fully open. The "slice" is called a work section. I am presuming the section with the spool and flow control? CJ
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A51691)
2024 Wanco...
Year: 2005 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2005 Make...
2013 Ford F-550 4x4 Ext. Cab Service Truck (A55788)
2013 Ford F-550...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
