Krylon's "Kubota Orange"?
   / Krylon's "Kubota Orange"? #1
KB4330
Rural Oregon
Kubota GL 4330, Toro 522xi Garden Tractor w/dual rear tires & 42" MMM
Krylon\'s \"Kubota Orange\"?
Saw this for the first time at the local hardware store today . It's labled as "Farm and Implement". They had some Deere green and yellow as well as a couple of other brands colors. Has anyone tried the Kubota Orange? Is it a good match?
Kevin
   / Krylon's "Kubota Orange"? #2
Re: Krylon\'s \"Kubota Orange\"?
How much does the can cost? I have been buying the 1620 chevy orange at walmart for about $3.50 a can. It matches pretty good.
   / Krylon's "Kubota Orange"? #3
I haven't seen that one, but I will be looking for it. Thanks for the tip. I have been using "Allis Chambers Orange" from Ace hardware. It is a perfect match for the Kubota Grand L color.
I think the price was $3.99 a can. Our local hardware store is an Ace "affilliate" so you can probably have them order it, esp. since they carry the one for Allis. I think I will pick up a can next time and give it a try. BTW, the can sku sticker says "Intended to Match 1821 Kubota Orange/Anaranjado"
Kevin
   / Krylon's "Kubota Orange"? #5
I bought a can at my dealer for around $7.00. He asked what year I had. They have two oranges, the caps on the cans are close but not the same. Kubota changed it slightly on newer tractors. Krylon is laquer. The Kubota stuff is acrylic enamel which seems more durable to me. It matches perfectly.
   / Krylon's "Kubota Orange"? #6
The #1620 Chevy engine orange is located in the automotive section of the Wal-Mart store. It is called Duplicolor.
   / Krylon's "Kubota Orange"? #7
You have to be careful putting lacquer over fresh enamel. Unless the enamel is old and well cured, the lacquer will cause the enamel to curl and wrinkle and then you will have a real painting challenge to repair it... That is the way it was 35 years ago, so I assume that it is still the same today... Junk.....
   / Krylon's "Kubota Orange"? #8
Krylon makes both, acrylic enamel and laquer. I use the fast dry stuff (12 min.) in acrylic enamel and it works great, and only 2.58 a can (WalMart). /forums/images/graemlins/grin.gif
   / Krylon's "Kubota Orange"? #9
I puchased two cases of the Allis Chambers Orange when my local hardware store had them for sale for $1.00 a can.
Learned real quik that it does indeed curl acrylic paint. /forums/images/graemlins/shocked.gif
Will use them for painting DIY projects. /forums/images/graemlins/wink.gif
   / Krylon's "Kubota Orange"? #10
</font><font color="blue" class="small">( Kubota changed it slightly on newer tractors. )</font>
car you define NEWER? APPOX year when they changed color? if you know! Thanks
2012 Peterbilt 382 T/A Day Cab Truck Tractor (A55788)
2012 Peterbilt 382...
UNUSED LANDHONOR LHR-LB9510 GAS LEAF BLOWER (A54757)
UNUSED LANDHONOR...
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
2019 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A53421)
2019 John Deere...
2008 Ford Focus SEL Sedan (A54815)
2008 Ford Focus...
2018 JLG 4045R 40ft Electric Scissor Lift (A55787)
2018 JLG 4045R...
