Krylon's "Kubota Orange"?
   / Krylon's "Kubota Orange"? #1
KB4330
Rural Oregon
Kubota GL 4330, Toro 522xi Garden Tractor w/dual rear tires & 42" MMM
Krylon\'s \"Kubota Orange\"?
Saw this for the first time at the local hardware store today . It's labled as "Farm and Implement". They had some Deere green and yellow as well as a couple of other brands colors. Has anyone tried the Kubota Orange? Is it a good match?
Kevin
   / Krylon's "Kubota Orange"? #2
Re: Krylon\'s \"Kubota Orange\"?
How much does the can cost? I have been buying the 1620 chevy orange at walmart for about $3.50 a can. It matches pretty good.
   / Krylon's "Kubota Orange"? #3
I haven't seen that one, but I will be looking for it. Thanks for the tip. I have been using "Allis Chambers Orange" from Ace hardware. It is a perfect match for the Kubota Grand L color.
I think the price was $3.99 a can. Our local hardware store is an Ace "affilliate" so you can probably have them order it, esp. since they carry the one for Allis. I think I will pick up a can next time and give it a try. BTW, the can sku sticker says "Intended to Match 1821 Kubota Orange/Anaranjado"
Kevin
   / Krylon's "Kubota Orange"? #5
I bought a can at my dealer for around $7.00. He asked what year I had. They have two oranges, the caps on the cans are close but not the same. Kubota changed it slightly on newer tractors. Krylon is laquer. The Kubota stuff is acrylic enamel which seems more durable to me. It matches perfectly.
   / Krylon's "Kubota Orange"? #6
The #1620 Chevy engine orange is located in the automotive section of the Wal-Mart store. It is called Duplicolor.
   / Krylon's "Kubota Orange"? #7
You have to be careful putting lacquer over fresh enamel. Unless the enamel is old and well cured, the lacquer will cause the enamel to curl and wrinkle and then you will have a real painting challenge to repair it... That is the way it was 35 years ago, so I assume that it is still the same today... Junk.....
   / Krylon's "Kubota Orange"? #8
Krylon makes both, acrylic enamel and laquer. I use the fast dry stuff (12 min.) in acrylic enamel and it works great, and only 2.58 a can (WalMart). /forums/images/graemlins/grin.gif
   / Krylon's "Kubota Orange"? #9
I puchased two cases of the Allis Chambers Orange when my local hardware store had them for sale for $1.00 a can.
Learned real quik that it does indeed curl acrylic paint. /forums/images/graemlins/shocked.gif
Will use them for painting DIY projects. /forums/images/graemlins/wink.gif
   / Krylon's "Kubota Orange"? #10
</font><font color="blue" class="small">( Kubota changed it slightly on newer tractors. )</font>
car you define NEWER? APPOX year when they changed color? if you know! Thanks
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
(2) UNUSED 18.4-30 TRACTOR TIRES (A54756)
(2) UNUSED 18.4-30...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
Honda EU3000is Gasoline Companion Inverter Generators (A55851)
Honda EU3000is...
UNUSED IRANCH SEMI AUTOMATIC QUICK CHANGER (A54757)
UNUSED IRANCH SEMI...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
