kubota 4560 backhoe
/ kubota 4560 backhoe #1
matt201150fd
kubota
I was wondering what gpm pump Ineed to run the l4560 backhoe. the pump failed the dealer want to sell me his pump and won't gve me any specs. I want to get a prince pump parts are avail and will last longer than this pump . any help would be great
/ kubota 4560 backhoe #4
I don't really know the spec's on that hoe, but I would think you could run that hoe with anywhere from 6 to 10 GPM. The higher flow would give you faster operation but also takes a little more horse power. 2500 psi at 6 GPM is about 10 HP where as 10 GPM is about 17 HP. You do not say what size tractor you have. If you have a smaller tractor, say about 2500 lbs, then you should go with a 6 to 8 GPM pump. If your tractor is on the order of 3500 lbs or more, then it could probably handle the higher speed of the hoe with a an 8 to 10 GPM pump.
/ kubota 4560 backhoe #5
I'm reading 7.8 gallon minimum.
2018 John Deere 4052M (A64126)
2018 John Deere...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2022 Takeuchi TL12R2 (A64126)
2022 Takeuchi...
SWINGTEC D-88307 COLD FOGGING APPLICATOR (A64276)
SWINGTEC D-88307...
2025 HOMESTEADER 612IT 12FT ENCLOSED TRAILER (A59914)
2025 HOMESTEADER...
Kubota L175 Tractor (A62613)
Kubota L175...
