Thanks Hammy I think what it is going to come down to is me and going to the dealerships and looking at them closely and then getting a quote on the exact machine that I want. Thanks for all of your help and for the other input from the others.
MessickFarmEqu said:There are some major differences in the mechanics of the tractor. The Bransen is a sync shuttle that requires clutching between FWD and reverse, 95% of what Kubota sells is Hydraulic shuttles that you don't clutch. Kubota has the cheaper transmission available if you ask. You also have a dry clutch for the transmission, and probably the PTO as well (they don't say). If this is the case, your much more likley to be doing clutch replacments at $2,000 a pop, especialy with a sync-shuttle transmission. There is major expense in this stuff, its not as simple as picking two 60ish HP tractors as assuming they should cost the same. Thats not to say that there is not a place for an economey built machine, for your uses it may make sense. If thats what your after you can find other major brands, like New Holland and Deere that do offer cheaper high HP tractors with more simple technology (TD/TT-A). That way you'll have the more basic machine, but backed by a company who's ownership and distribution seems to change every 2-3 years.
nathan812 said:Not to mention the loader on the Branson has a 1000 pound advantage on lift cap
MessickFarmEqu said:No it does not. It lifts 3018 at the pivot pin. Kubota publishes a more honest bucket center measurement (where you actually lift the load) of 2536 lbs. Typically there is a 30% changes between bucket center and the pivot point, giving the bransen a real world ratting of 2100lbs... so really the Kubota has a 400+lb advantage. Of course your friendly dealer is not going to tell you that, nor will Bransens marketing dept. If you want to lift a 3000lb load with that tractor you'd be disappointed. It probably would not budge.
Having a dealer near by is an important consideration. If you feel comfortable buying there your probably making the right choice. Just make sure that you know what your money is actually buying you.
DavesTractor said:I do disagree that "your friendly dealer won't tell you that". I am a friendly dealer and I tell people how it is measured.
MessickFarmEqu said:Apparently someone did not though. Your missing my humor![]()
tydp said:Gee Arthur, Our Kubotas say manufactured in Japan all over the place. I don't see made in Korea anywhere (except on some of my cheapie throw away electronics devices). We all know of the execellent quality of those..![]()
art said:Sorry but I was just being a little sarcastic! I haven't seen any two pieces that can really be made quite the same much less tractor quailty being a flat line from brand to brand.
Many of the newer economy tractors are just old die's being used again.
I paid $7500.00 for my old Harley and it will still bring $7500.00.Hammy said:I also agree that you're not buying a tractor as an investment, they all depreciate, including Harley's.
Craig
