Kubota 7040 run 14Ft. haybine???
   / Kubota 7040 run 14Ft. haybine???
I think that may still be to big for your tractor
I would go with a 9' New Holland or similiar
How much do you need to mow?
I did a seach on the net and found a new holland page that says it needs 60 hp to run and weight is approx 4800 lbs. I cut around 160 acres. In 2 more years I should be up to 320/400 acres to cut.
Todder
You did not mention much about your 7040, they can be setup light or heavy. Is yours 2wd or 4wd? Cab or rops? Cast iron rear wheels? Filled rears? Front end loader on that machine? What did you eat for lunch (just kidding there ...).
Sorry, I'm not familiar with the power requirements for those implements.
My 7040 is 4wd, cab, cast iron rears, loader, no tire fill. For lunch today I may have chili.
Todder
   / Kubota 7040 run 14Ft. haybine??? #13
I would think your 7040 could handle it, my FIL has a 9' NH mower conditioner (cant remember the model, it has a sicklebar to cut and rubber rollers to crimp) that we pull behind a L3830GST with loaded rear tires. It handles it very well as long as you keep the speed up (it leaves uncut grass when you put it down in 3rd or 4th) and aren't in super thick grass.
Aaron Z
   / Kubota 7040 run 14Ft. haybine??? #14
Todder
If you are cutting that kind of acreage I wouldn't mess around with a sickle mower. A discbine would be the only way to go then IMO.
   / Kubota 7040 run 14Ft. haybine??? #15
Todder
Actually it was a valid question. A center pivot haybine or disc mower conditioner puts different and greater lateral forces on a tractor than a side pull model, especially on hills and while turning. If you intend on covering 300-400 acres of hay ground in the near future, a center pivot machine is probably something you should look at, but you don't have near enough tractor to run one safely and effectively.
Duffster, Why a discbine over a haybine??? What the #%$$* does IMO mean??
Todder
Rick
I'm not sure if I have this correct. The 499 Newholland 12ft. I'm looking at is a center pivot machine which requires 60 hp and weighs about 4800 lbs. Still not big enough to cover off these acres?
Todder
I n
M y
O pinion
thank you
   / Kubota 7040 run 14Ft. haybine??? #20
You will need a bigger tractor (at least 85-90pto), and preferably cabbed, to run a 9' + discbine.
2019 KENWORTH T880 DAY CABROAD TRACTOR (A51406)
2019 KENWORTH T880...
BENNU HYD SCAFFOLDING SYSTEM (A52706)
BENNU HYD...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
2007 Hyundai Sonata GLS Sedan (A54815)
2007 Hyundai...
Unused Delta Crash...
96" X 53' FLATBED TRAILER (A52706)
96" X 53' FLATBED...
