Kubota 7060 question
   / Kubota 7060 question #21
So, is the 12x12 transmission an upgrade from the 8x8?
Is the 12x12 a wet clutch and 8x8 a dry clutch?
I am looking at specs online, but one of us is not extremely clear.
Thanks!
Yes, the 12X12 is an upgrade and is not inexpensive.
I specified it for my M9960 ROPS so as to reduce the need to stop to change ranges while mowing.
SDT
   / Kubota 7060 question #22
Lots of good advice here already!
I don’t think you’ll go wrong either way with the transmission choice. Having the extra gears can’t hurt, trying to find that ideal speed while mowing or whatever.
I do a lot of road travel so the 12 was the only way for me.... 40kph (~25mph) top speed is nice on a 10 mile run.
With the road travel pulling the dump trailer I also do some loader work and and a fair bit of slow idling around but the Highway driving must load up things enough the DPF does not regen very often.
I was told by someone the creeper gears are not overly robust and not meant for heavy work?’looking at the shop manual it does not look like a terrible job to install them at a later date yourself if you want them?
I have the 3 rear outlets and use them all at different times.
Does the 8x8 also come with all the adjustability gadgets on the 3pt hitch the same as the 12sp cab model?
I sometimes find the machine is slightly large for what I want to do (in a backyard, in the woods) but that’s More than made up by the lifting and towing capacity that would take twice the trips with a smaller unit. This M7060 to me is a Swiss Army knife tool, (a 3/4 ton towing and snow plow truck, skid steer, atv, field mower) so I’m happy to have the 12 speed, the cab, the extra rear outlets, and all the other luxury options that I likely don’t notice but would without them! Money well enjoyed more so than well spent but enjoyed makes it well spent. (I bought used and saved 15-20g off list price for a 2 year old machine with 250hrs)
   / Kubota 7060 question #23
i have an M8540 12x sp so that upgrade may be different on the xx60 series.... the added 12sp gears are very useful. the upgrade also increased my 3ph hyd lift capacity a lot (not sure on the specs) the lift cyl are also external. i highly recommend the upgrade
the 12 sp upgrade will increase your working speed versatility, so you may not need the creeper gear. what will you be using it for?
btw the creeper gears are not intended for soil engagement or heavy Fel work. more like seed drills, etc. apparently the gears are not as robust as the std gear for heavy work
anyway go with the 12sp if you have the option
   / Kubota 7060 question #24
I believe the electronic 4x4 puts the tractor in 4x4 when the brakes are applied so it may be a little safer for the guys that start down a hill with a heavy trailer in 2wd. it would be interesting to know top speed of 8x8 vs 12x12.
Can someone tell me how many years the emmission system on the 7060 has been out, or in production?
   / Kubota 7060 question #27
Can someone tell me how many years the emission system on the 7060 has been out, or in production?
From day one of the M7060 introduction and I think that was from the tail end of 2013. I'm not aware of anyone with an emission issue on the M7060 and guys seem to operate them in all sorts of RPM conditions.
Thank you. I have not come across any issues that have been posted online either, that I have found. 7 years in production sounds pretty good.
   / Kubota 7060 question #29
I would have paid for the power shifting 24 speed transmission when I bought my M9960, but I needed a ROPS model and the 24 speed transmission is exclusive to cab models.
SDT
   / Kubota 7060 question #30
Here’s the ground speed chart linked from another thread
https://www.tractorbynet.com/forums/kubota-owning-operating/401235-m7060-ground-speed.html
2019 ISUSZU NPR BOX TRUCK (A56129)
2019 ISUSZU NPR...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
JOHN DEERE 6135RW401 MOTOR (A51247)
JOHN DEERE...
2005 Mack Quad-Axle Dump Truck (A55788)
2005 Mack...
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
72" HYD QUICK ATTACH GRAPPLE (A51406)
72" HYD QUICK...
