EE_Bota
Veteran Member
well, got the b7800 back today. the dealer got the valves adjusted and fully tested the glow plugs. the glow plugs were working fine. only thing is the amps were a little less at plug. dealer said that could run a new cable to give better current, but not really worth it at this time.
on to the valves. just for everybody's record, my kubota engine did need adjusting at 895 hours. they weren't terrible, but here are the numbers.
#1= ex .010 in .0085
#2= ex .0105 in .010
#3= ex .009 in .007
#4= ex .0105 in .0085
specs for v-1505 e2 d16 diesel engine are .0057 to .0073
all valves are now .007
engine seems smoother, but might be my imagination. i also haven't run it much, only to and from the trailer to the shed, where it will now get its 900 hour pm. (oil, hydraulic, etc.)
as far as it starting hard in the cold, have to wait for a cold day. dealer said everything seems fine and will just chalk up future small hard cold starts to normal wear and tear=895 hours. can glow plug it longer if feel the need. 15 to 25 secs.
dealer said it was worth it to due the valve adj, atleast for me. tractor actually came back cleaner then when i took it, and i washed everything just before i took it and i am fussy too, so dealer did a great job, and i will be taking the tractor back around the 15001600 hour mark to do the valve adj again and the 1500 hour fuel injection nozzle injection pressure check. do them both at the same time to save a trip.
i will try to update ,if i remember, starting on a cold day if the valve adj did anything to fix that cold start problem.
Good job...It should give you peace of mind that you have received a pretty good bill of health for your tractor. If you don't have a service manual for your tractor, consider treating yourself to one. You seem like the kind of fellow who would like one, since you are curious, like to learn, and you like your equipment clean and right.
