Kubota B2150 Electical Problem
   / Kubota B2150 Electical Problem #1
geoteck
Kubota B2150
I just bought a Kubota B2150 tractor and it appears as if the lights don't work. The hazard flashers work, but the headlights and taillight do not come on. The dash lights work also. I have been looking for the fuse box to no avail...I do not have an owners manual, so have no idea where to look. I also do not have a wiring diagram. Can anyone point me in the right direction?
At first I thought the problem might be a fuse, but usually the dash lights are wired in with the head and tail lights...
Any assistance would be appreciated! Thanks! -rich-
   / Kubota B2150 Electical Problem #2
I have a B2630 and the fuse panel is located on right side inertia firewall of the dash. I just have to pop the hood to see it. Yours is most likely located in the engine compartment also.
Thanks! I'll take a look in the morning! -rich-
Thanks! I found the fuses...they were not on the firewall. They are in a branch of the part of the wiring loom that goes to the engine stop solenoid and sit on the top of the engine near the intake manifold. Let me know if you also need help finding them on your B2150 and I'll send you some photos.
The lights are fixed and it was not a blown fuse! The tail light was not grounded and the headlights had loose and dirty contacts... All is well again!
Thanks again! -rich-
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2012 DOOSAN G25 GENERATOR (A58214)
2012 DOOSAN G25...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2019 FREIGHTLINER...
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
16001 (A55853)
16001 (A55853)
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
