Kubota B2650 & B3350
   / Kubota B2650 & B3350 #51
Thanks to all the information I found on this site and thread, I ordered a B2650 cab and get it in two weeks! I was "afraid" of all the issues with the tier 4 and the 3350...I will keep you all posted! Thanks!!!
   / Kubota B2650 & B3350 #52
When considering the two models - even though the larger version has more HP - some of that power will be lost with the fuel soaking DPF muffler - all in all the best bet is the 2650 you get a clean engine and you have $5k for fuel or goodies to hang on the beast. I have a B21 and while it does not have ton's of power, its fine and will dig like crazy.
   / Kubota B2650 & B3350 #53
When considering the two models - even though the larger version has more HP - some of that power will be lost with the fuel soaking DPF muffler - all in all the best bet is the 2650 you get a clean engine (new 4 cylinder) and you have $5k for fuel or goodies to hang on the beast. I have a B21 and while it does not have ton's of power, its fine and will dig like crazy.
Not arguing about which is best, but to keep the record straight:
The B2650 has a 3 cylinder engine while the B3350 has a 4 cylinder engine (bore and stroke is the same).
The B3350 does have the "nasty" DPF, but it has a turbo to make up for the DPF power loss. This may be more important if you live at a higher altitude as a normally aspirated engine looses 3% per thousand feet.
So I'd say it depends on one's circumstances as to which is the better choice.
bumper
   / Kubota B2650 & B3350 #54
Save $5,000 and get a clean engine without all the electronic crap - there's little to think about!
New/Unused Quick Attach Stump Grinder (A57454)
New/Unused Quick...
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
2012 Infiniti G25 Sedan (A56859)
2012 Infiniti G25...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
24in pin on excavator tooth bucket (A56436)
24in pin on...
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
