Kubota B2650 PTO Selector Lever
   / Kubota B2650 PTO Selector Lever #1
clemnd86
Wareham, MA
Kubota BX 2200
I cannot switch my PTO from rear PTO to mid PTO. The lever is stuck/binding. I have tried engaging the rear PTO and then trying change the selector lever and still was not able to change to the mid PTO. I applied spray grease at the lever to loosen the joints and the lever is still binding. Any thoughts what is wrong?
   / Kubota B2650 PTO Selector Lever #2
Not sue but it seams like there is a issue with the mech. Did it work before ?
   / Kubota B2650 PTO Selector Lever #3
Instead, use a penetrating spray where the shafts enter the case.
   / Kubota B2650 PTO Selector Lever #4
On my BX I had a loose bolt from one of the many brackets on the underside block the linkage.
I took it to the local dealer he was able to get it unstuck and one of the linkages was bent that he needed to straighten. Working good now.
John Deere 506 3 pt Mower (A50515)
John Deere 506 3...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2024 AGT KFE-20 2,000lb Electric Forklift (A50322)
2024 AGT KFE-20...
Vermeer SC802 (A50322)
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2012 PETERBILT 337 (A50854)
2012 PETERBILT 337...
