Kubota B2920 how to make 12v connection
   / Kubota B2920 how to make 12v connection #1
biker01red
Troy, Ohio
Kubota B2920
I just purchased a Kubota B2920 tractor. How do I establish a 12V plugin connection for my sprayer attachment?
   / Kubota B2920 how to make 12v connection #2
The Kubotas used to have, and I would assume still do have, a wire and connector under the driver's seat for auxilliary lights or whatever. I used that for a spray rig. It was a little hard to find because they had taped it to another wire with enough tape that the connector was completely covered and didn't show.
Thanks for the information, I will check and let you know what I find...
   / Kubota B2920 how to make 12v connection #4
The connector for auxiliary is under the right fender. I can't remember what it is fused for, but it terminates to a male and female bullet connector. It is only hot when the key is on.
   / Kubota B2920 how to make 12v connection #5
various diagrams. *shrugs*
I checked under the seat, no accessory plug there. The only wiring there is the pressure switch that turns off the engine if the rider leaves the seat while the power takeoff is running.
Yes, I checked, the connector is there under the right fender !!!!! Thank you very much for the info..... I just need to get the correct bullet connector size and I am in business..... Thanks again.
   / Kubota B2920 how to make 12v connection #8
Why doesnt the B series have a 12v stock when the BX does?? Where is the Kubota logic in that??
   / Kubota B2920 how to make 12v connection #9
It's there. Under the right side fender. Just understand, the B2x20 series is like the budget small AG/industrial tractor. The BX is more of the estate tractor. More likely to have a 12v accessory socket and cup holder.
Yesterday I got a bullet connector and an SAE plug to match the one on the sprayer, made the wiring attachment on the tractor for the plug, attached the sprayer, and it works just fine !!!!! Thanks again "skspurling" for the information...
For your info, I called my dealer and ask about the plug before posting on this site, they wanted to sell me a separate wiring harness with the plug included for $55.00.....they didn't tell me about the one already there under the fender !!!!!
Danhauser 3 pt Post Hole Digger (A50515)
Danhauser 3 pt...
SCAN TO RECEIVE TEXT UPDATES (A51244)
SCAN TO RECEIVE...
UNUSED FUTURE MINI EXCAVATOR HYD THUMB (A51244)
UNUSED FUTURE MINI...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2014 International Durastar 4300 Terex BT3063 30,000lb 63ft Crane Truck (A50323)
2014 International...
Parker 4000 Gravity Wagon (A50774)
Parker 4000...
