Kubota B3030HSDC
   / Kubota B3030HSDC #1
rschulte
Dear Group:
I am contemplating buying the Kubota 3030HSDC. My dear wife is intrigued by the prospect of cutting our lawn in air-conditioned comfort. Aftering looking at some comporable Deeres, New Hollands and the like, the B3030 remains our top choice and, frankly, the cab cinched it for the Mrs.
My dilemma is this - it would appear that a backhoe cannot be mounted on the cab version of the 3030. If so, that would greatly limit the utility of the tractor for our intended use.
Is this true? It seems a rather unfortunate to have to choose between a/c and ability to use a backhoe.
Is there a third-party vendor backhoe that would work with this tractor?
Your collective wisdom is, as awlays, most appreciated.
Regards,
Rob S.
   / Kubota B3030HSDC #2
Check out the Woods back hoe, I believe the make one cab compatible.
   / Kubota B3030HSDC #3
Woods does have one to fit, although it is further to the rear then the factory Kubota and a disadvantage on leverage they do work.
   / Kubota B3030HSDC #6
Rhino also makes one; I have one (albeit a larger model) on my 5030HSTC.
Woods is a good brand; regardless of the brand you get, get a subframe mount (stay away from a 3 point backhoe mount, they are prone to damaging the tractor)
A subframe mount BH goes on and off easily, and the subframe gives substantial rigidity to the mount lockup.
   / Kubota B3030HSDC #7
Art, why do you say it's a "disadvantage on leverage"? It's actually just the opposite... the effective lever arm (distance between stabilizers and FEL bucket, which should be the only things on the ground) is longer in this setup. Not that it makes much difference though.
Rob S., the Woods BH80-X 4-pt subframe mount would be the most appropriate for the B3030HSDC, especially with the extra weight of the cab. The BH70-X might leave you wanting more. With the Woods you also get the curved boom, more bucket options, the thumb option (which I highly recommend), and a 2-yr warranty. The BH80-X also has the most digging power in its class.
   / Kubota B3030HSDC #8
The further the pivot is the rear the more stress to the clutch housings which is the way the commercial units are made. There are other things to, normally when trailering the pivot will drag while loading andunloading.
   / Kubota B3030HSDC #9
You lost me... what clutch housings on a B3030? What stress? And what would that have to do with "leverage" for the BH? Just like the Kubota subframe, the Woods subframe runs the full length of the tractor and is bolted to the tractor frame. Both subframes also locate off of the rear axle housings (is that what you meant?), but if you compare the two the Woods subframe has extra reinforcement in this area and is obviously the stronger of the two. The axle housings may bear a small amount of axial load for either subframe, but none of the torsional loading from digging - that's bore by the subframe and transferred to the tractor frame. I fail to see your point.
You're correct about the trailer loading/unloading concern aka "angle of departure", but it depends on more than just how far back the swing pivot is. The Woods has 15 degrees whereas the BH75 has 18 degrees, which amounts to about 1.25" extra clearance for the BH75. I don't think that's enough of a difference to be deal-breaker, especially if it means the difference between having a hoe or not on a B3030HSDC if you really want one.
   / Kubota B3030HSDC #10
Think in terms of torque
The BH80 is applying a force (lets say 2,000#) at the bucket X feet (lets say 5) from the tractor = a torque of 10,000 FT-LBS that the tractor/subframe has to resist. On the cabbed tractor that distance will be more - not sure if it is 6" or 1foot but the torque would be 11,000 - 12,000 FT-LBS for the same 2,000# digging force at the bucket.
The subframe is not infinitely rigid & will pass some of the forces/torques to the tractor components/castings. With larger torques applied, the chance for damage is greater. Weather it is cause for concern, I don't know. That would involve a much more detailed analysis with information on the metalurgy of the various parts - subframe, castings etc... The added torque will make it easier to bounce the tractor around with the hoe (pulling against an unmovable stump for example).
Perhaps the BH70-X is the better choice for the Cabbed B3030...
   / Kubota B3030HSDC #11
In reading it I guess I was a little, I don't know. All I know that the more leverage I see in the hoe past the axle the more of those units will be broke, loaders out the front must be about the same as a fellow I know that has a full subframe under the tractor still broke it at the clutch housing area (or back of engine) and he said he didn't have the backhoe on the the time, not to say it might not have been broke before then. Not bad for a 250 hour tractor, I won't give out the brand but I should have it in shortly after he gets it back from the dealer as it's his second time on the same make.
I know that the manufacturers of many of the backhoe's say they will pay if it causes damage to the tractor if the tractor company won't, but it seems that the bulk of the time they are out of warrantee by the time the damage shows up.
   / Kubota B3030HSDC #12
Indeed I was. Torsion(al loading): the twisting of a body by two equal and opposite torques. We're both talking about what's happening in the Z-plane, along the longitudinal axis of the chassis & subframe. Correct?
The BH80 is applying a force (lets say 2,000#) at the bucket X feet (lets say 5) from the tractor = a torque of 10,000 FT-LBS that the tractor/subframe has to resist. On the cabbed tractor (well, the tractor with the Woods vs. Kubota hoe...cab is irrelevant) that distance will be more - not sure if it is 6" or 1foot but the torque would be 11,000 - 12,000 FT-LBS for the same 2,000# digging force at the bucket.
Agreed. To keep things simple, we'll ignore the stabilizers (fulcrums) and consider the 4-pt mount to be the (only) point where the two torques counteract (highest stress). The torque that counteracts the hoe is the basically the weight of the tractor (force) X the distance from the FEL bucket at ground to the 4-pt mount. Now the missing piece ... the counteracting torque the tractor can supply is finite. When the hoe exceeds that guess what happens... the hoe picks the tractor up. Now the point where the two torques meet has transferred more or less to the swing pivot. If the swing pivot is further from the tractor, the torque available to counteract the hoe is greater*... therefore the overall leverage it has is greater, not disadvantaged. This is what I challenged. Throw on the weight of the cab, that advantage increases.
(* Simplification is that the tractor weight is distributed evenly, but depends on where the CoG really is. The weight of the tractor is increased by the additional mass of the longer backhoe mount/operator platform. The operator also sits further from the tractor. Both of these move the CoG closer to the hoe, increasing the counteracting torque. True that if BH were simply moved back further and the CoG unchanged, the BH's leverage would actually decrease).
The subframe is not infinitely rigid & will pass some of the forces/torques to the tractor components/castings. Agree. In that simplified analysis I'm treating all components as rigid bodies, which there'd better be enough margin designed into them to make that a good approximation.
With larger torques applied, the chance for damage is greater. Weather it is cause for concern, I don't know. If this were the perceived "disadvantage", then yes absolutely I think we're all on the same page. But let's say the chance was 10% (1 in 10) to start, and it's now 20% worse, should I lose sleep over it being 12% instead?
True. Guess I give the guys at Woods alot more credit for designing the subframe beefy enough to handle it. If you compare the Kubota and Woods subframes, you'll see what I mean. Also keep in mind the torque (torsion) in the subframe and chassis decreases the further away from the hoe you get (to zero at the FEL bucket).
Not easier at all.. again, the hoe can only impart as much torque to the tractor as the tractor can counteract. Also if you're pulling straight up on the stump, the craning ability of the BH boom limits your ability way before, say, you can pull the FEL off the ground.
Respectfully disagree. Sits just as far back as the BH80-X (if that's the concern), and has only about 18% less power. Its main disadvantage is with the reduced reach... also doesn't have the swing speed regulator which is a nice feature. Besides, I thought downsizing wasn't allowed here :)
   / Kubota B3030HSDC #13
I see now where our analysis divirge.:)
You are defining the pivot point as the swing pivot. I was thinking in terms of the rear axle. It depends on the operating conditions.
In my soft ground, when pulling on a stump, the stabilizer pads head towards China & the tractor pivots on the rear tires - thus the "disadvantage" - meaning the futher back the hoes is, the easier to pick up the tractor.
If the pads were on a suffeciently rigid surface - ie a paved road of some sort, there would be more torque available to conteract the bucket forces as the unit would be pivoting on the stabilizers not the rear axle. The tractor would be experiencing less stress.
One thing we haven't considered is transport. The further back the backhoe is, the more torque it is applying as you bounce down the field. My "gut feel" is that I'm imparting as much if not more forces thru the machine while transporting (impacts loading of bumps) vs. digging (where I have control over how much force is applied) - gotta learn to slow down a bit:eek:
   / Kubota B3030HSDC #14
PS - I meant to ask you - how does the 12" bucket work with the thumb? I've got an 18" & 9" bucket. The sides of the 9" interfere with the thumb - doesn't work so hot... I understand that on anything smaller than the 16" bucket the teeth may not line up.
   / Kubota B3030HSDC #15
If you had to choose one backhoe bucket, which size do you consider to be the most versatile?
Thanks!
The Gardener
   / Kubota B3030HSDC #16
The Gardener said:
If you had to choose one backhoe bucket, which size do you consider to be the most versatile? Thanks!
The Gardener
16" or 18" (flip a coin)
   / Kubota B3030HSDC #17
Agreed. I thought we were talking about breaking ground/digging in (backhoe wants to lift tractor). You're talking about pulling tractor down as hoe wants to lift stump/rock/Volkswagen/whatever.
That's true (good analogy), the backhoe does have more leverage against the tractor in this situation. Ya gotta try your best to keep it on the stabilizers though, you really don't want to be putting the stress on the rear tires/axles. I have a couple of pieces of old rubber truck bed mat I throw under the pads for times like this.
My previous post was to show that the tractor has more torque to counteract the hoe as it tries to lift it's rear end up. It would only be easier if weight and CoG didn't move in the tractor's favor. But maybe you're still referring to pulling the tractor down, not lifting the rear as I am. You'll never lift the tractor (front end) with the hoe trying to pick something up... it doesn't have that kind of craning power. Maybe if you left the FEL off ;)
Exactly!
Agree, but how much more? 5%? 10%? We need somebody to actually measure the difference between the two, but it's not like the Woods hangs an extra 2 feet out the back. I could swear it's only a few inches if anything. On both of them the ROPS has to be up and the seats touch back-to-back with the tractor seat. If you haven't seen it, check out the following comparison from Woods' site:
http://www.woodsequipment.com/dare_to_compare/backhoes/bh80-X/BH80-X%20DTC%2010-05.pdf
Hmmm... I think the shock of the hoe lifting the tractor and then dropping it back on the stabilizers is worse... I try not to let that happen. The tires at least absorb some of the shock of transporting.
Yep. I wouldn't carry the hoe in H range over uneven terrain... you do know it's back there.
   / Kubota B3030HSDC #18
It works fine with the 12" but the sides of the thumb just fit between the two outer teeth...so I can picture what you're saying about the 9". The shearing action on the 12" is pretty good, will snap smaller limbs in two like a snapping turtle. I'll get a couple of pics for you. I almost bought a 9" thinking it might be cheaper and better to trench with, but it was only $50 less than the 12". Price differences between the various buckets isn't as much as one might think... seems to be a hefty upfront "bucket tax" that's a big chunk of every one.
   / Kubota B3030HSDC #19
I'd love to see some pix. Perhaps we should start a new thread as we are definitely hi-jacking this one...:eek:
I'm going to shoot an email to my salesman to see if he'd be interested in trading the 9 for a 12...
   / Kubota B3030HSDC #20
I had my dealer install a BH80-X w/thumb this April. I was very reluctant. I'm use to switching implements often and thought oh what am I getting myself into. The dealer had a good price $7200 installed with frame so I gave him the go ahead. Best choice for this tractor (b3030cab) I can tell you. Stable when not in use. 10 inch ground clearance. Powerfull bucket. Great stump puller. Oh that thumb is handy. Can open rear venting window without moving seat. Can reach back from drivers seat through rear window and reach controls in case it needs to swing it L or R to avoid obstacles. Hoe comes off in 5 min. And back on in about 8 min. Takes longer to thread the bolts. The one drawback is the unit will barely bottom out on a std. trailer ramp so I carry a couple 5ft. planks for loading. Rear work lights on cab are high enough to do the job and not cast a shadow from your head in the way. A smaller hoe I would be kicking myself. It's perfect!
PowerBoss Admiral Plus 38C Ride-On Floor Scrubber/Sweeper (A59228)
PowerBoss Admiral...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2008 CATERPILLAR 420E BACKHOE (A59823)
2008 CATERPILLAR...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
