kubota B6100 hydr leak
   / kubota B6100 hydr leak #1
Anonymous Poster
Epic Contributor
I parked my B6100 after about 2 hours of mowing and noticed a large puddle of Hydraulic oil had leaked out from the the PTO shaft on the tractor. I checked the dip stick and it was dry. I use a Woods finishing mower. Did I blow a seal? How costly is this to repair?
   / kubota B6100 hydr leak #2
I don't know about the B6100, but the parts manual for my B2710 shows an ordinary oil seal around the rear PTO shaft (and I would expect the B6100 to have a similar one); however, the shop manual says nothing about how you replace it. I'd be strictly guessing, but suspect it's a fairly simple repair.
Bird
   / kubota B6100 hydr leak #3
Since your sure its leaking from the pto shaft and not the gasket replacing the seal will be easy but time consuming...2 to 3 hours.
Cost for the seal assemble and gasket for a B7100 was $62.oo couple years ago.
Good luck.
I'm not sure about the B6100 transmission,but there also could be a rubber 'o' ring in side check to see if its okay.
Thomas..NH
   / kubota B6100 hydr leak #4
If you shouldn't have a parts manual you might be interested in Jensales Inc.
There maunual are great,for they show the complete break down on all areas.
Telephone number. 1-800-443-0625
I'm not sure if Jensales Inc still located on Yesterday Tractor website.
Good luck.
Thomas..NH
   / kubota B6100 hydr leak #5
Recently while using a rotary mower on my B2150 grass got wrapped around my mid-PTO and damaged the seal and it started leaking.
The replacement seal cost under $10. I had to drain all of the hydrostatic fluid (just under 5 gallons) and then the seal just slid off over the PTO shaft. The new one slid right back on into place. So far, no more leaks.
I would recommend changing the hydrostatic fluid filter, clean the suction screen and put in new fluid (sounds like you have no choice there...).
Don't know how similiar the B2150 mid-PTO seal replacement and the B6100 PTO seal replacement are, but I thought I'd throw this information in nonetheless.
   / kubota B6100 hydr leak #6
ok, how did it go??? give us an update on what you found on the cost of the parts and what was involved in the change. I have a B6100, so i am real interested in all repairs or problems;
heehaw
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
2011 Ford F450 Bucket Truck (A47384)
2011 Ford F450...
2015 FORD F450 XL SUPER DUTY SINGLE CAB SERVICE TR (A51243)
2015 FORD F450 XL...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
