Kubota B7510 on car hoist?
   / Kubota B7510 on car hoist? #1
Rod in Forfar
Platinum Member
Forfar, Ontario, Canada
1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
After 15 hours of mowing our rather rocky green space, the blades on the mid-mount mower of the Kubota B7510 I recently brought home need service. The centre blade came loose yesterday and I was able to find a 30 mm socket and breaker bar to reach in and tighten it. I also touched up the ends of the two blades I could reach but the other eluded my angle grinder. From the feel of the left blade it had also eluded the grasp of the tractor's previous owner.
A better solution: a couple of years ago we installed a 10,000 lb two post asymetric hoist in the new shop. It lifts my Polaris Ranger for oil changes without a problem. Because we installed the narrow version to save space, the arms will extend far enough to touch in the middle. The trouble is that the Kubota is all-tire-no-frame so lifting is more of a challenge. Has anyone put planks or a cradle on a car lift to raise a light tractor for mower service?
An hour on the Internet has turned up no photo of such an arrangement. Is this an Internet taboo I don't know about?
An interim fix would be to run the Kubota up on the aluminum trailer for my son's Porsche, but I'd rather have a permanent solution to this maintenance challenge.
Thanks,
Rod
   / Kubota B7510 on car hoist? #2
I wouldn't try it - failure would be very bad. Can you just remove the mower to service it? Or run tractor up classic auto ramps?
   / Kubota B7510 on car hoist? #3
Thanks,
Rod
I too have the same problem. For now Ill probably just use the trailer we use for my daughters Maserati.
   / Kubota B7510 on car hoist? #4
I find the Maserati trailers to be a bit too low. Much better to use one if the Rolls Royce trailers for the additional clearance.
   / Kubota B7510 on car hoist? #5
I could not fit under any of the 3 , but then I could always put it on the trailer before jacking it up , balance with care .
   / Kubota B7510 on car hoist? #6
I'd put a plank across and drive the front wheels over the plank and lift up the front end, block the rear end.
   / Kubota B7510 on car hoist? #7
Good Point. Both of my Rolls are at the dealer sitting on their trailer for a service. Ill try those when I get my cars back at the end of the week.
I decided on a trial run with a couple of hardwood boards to support the tires. I think the system shows potential, but it will need improvement before I get under the tractor.
Flickr: Kumpulan Foto Rod in Forfar
   / Kubota B7510 on car hoist? #9
NEW Fork Extensions (A48289)
NEW Fork...
2006 Volkswagen Jetta Sedan (A46684)
2006 Volkswagen...
2017 Ford F-150 Pickup Truck (A44571)
2017 Ford F-150...
2005 ISUZU NPR HD REFRIGERATED BOX TRUCK (A45677)
2005 ISUZU NPR HD...
2014 UTILITY 53X102 DRY VAN TRAILER (A45678)
2014 UTILITY...
2017 Nissan Sentra (A46684)
2017 Nissan Sentra...
