Kubota BX24 running rough, lots of white smoke
   / Kubota BX24 running rough, lots of white smoke #11
Would you be able to use the fel loader and backhoe on your other tractor? Would they work on a new tractor? Has the dealer given you any idea on a price you could sell them for? If yes to either of the first two I would think you would use them if not then would suspect you could easy sell them. Might help narrow price for buying new. I don't know on that size tractor but a full size tractor that age and if hours are reasonable and everything else is good...would fix it. If you fix it what would it then sell for? If you don't fix it the salvage value? I believe you will find it will sell for enough if you just repair it and then sell over selling it as is to justify the repair.
Pray you have a great recovery on the heart issues.
^^ If you can handle it, I'd suggest go new. Try to sell the old one to someone who needs a fixer upper and has the ability to do so. Or is that price with some sort of trade?
Just an FYI though, mine was less than that including a 48" tiller.
Diggin it, you are talking a BX with loader & backhoe plus a tiller ? Wow !!
From what I understand the loader and backhoe will not work with a new tractor. Would probably have to try and sell them if I go the new tractor route. Appreciate the prayers and I am slowly getting back to normal.
Well guys the motor ended up being beyond repair. Would cost more to fix it then buying a new motor. Decided to buy a new bota BX23S with loader and backhoe. Will have it by the end of the week. Question: going to try and sell the BX24 with loader and backhoe. Looking for recommendations on what I should try to sell it for. Dealer wanted $5400 to install a new motor. Only issue is the motor.
   / Kubota BX24 running rough, lots of white smoke #16
It is a coolant/water problem. Check compression and the radiator for bubbles, gaskets etc. could be a warped head.
   / Kubota BX24 running rough, lots of white smoke #17
A year or so ago, My sisters B7510 needed a motor..dealer quoted something like 7k to do the job. We found a very low hour salvage tractor and used that motor in hers. I did the swap myself.. ( my first time splitting a tractor ) It was a lot of work..more than I had planned on but it ended up fine. I was able to do everything but the injector pump and it went to the dealer for that and the initial start up. We paid 1500.00 for the doner tractor, maybe 400.00 in travel/fuel/tolls and another 1,000 to the dealer to button it up, and change all fluids. ..then sold the remnants of the doner tractor for 900.00... so she is all in for pretty short money with a very low hour motor. I think you can probably do the same as thoseBX tractors are so popular. .. The biggest problem may be finding a guy who will tackle the motor swap without going to the dealer.
6 Yard Commercial Dumpster (A51692)
6 Yard Commercial...
2020 MDB UT125KPLUS FLAIL MOWER (A51247)
2020 MDB...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
24' PIN ON EXCAVATOR BUCKET (A52707)
24' PIN ON...
