Mowing Kubota diesel overheating.
   / Kubota diesel overheating. #173
I had the same issue on my Kubota, as 4570man said, the belt had worn down to the point the belt had bottomed out in the pulley. it never made a sound as it slipped on the pulley but it wasn't turning the water pump fast enough to keep the coolant flow equal to engine speed. looking at it i noticed the top of the old belt was even with the top of the pulley groove. when I put the new belt on, the belt sat about a 1/16" above the pulley rim which meant the new belt was grabbing the sides of the pulley groove and not ridding on the bottom of the pulley groove, once it reaches that point the belt is shot, got your monies worth and time to replace.
   / Kubota diesel overheating. #174
Have seen many overheating problems in small diesels with weak injectors. A dry cylinder will do exactly what you have going on. Being used to larger diesels I found it odd but it is common in non-American builds.
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
2017 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2017 CATERPILLAR...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A53472)
2003 International...
(4) Drums of Mixed Fabric Softener/Detergent (A51573)
(4) Drums of Mixed...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
