johndinino
If you run a diesel engine too lean, temperatures spike and NOx emissions go through the roof. Just ask Volkswagen. They did that experiment, globally.
"Lean" diesels don't run hot. They run poorly.If you run a diesel engine too lean, temperatures spike and NOx emissions go through the roof. Just ask Volkswagen. They did that experiment, globally.
I deal with over heating every day. My MF7495 and Pottinger hay mower gets hay chaff on the hood gills and the rads practically on the hour. Especially if the hay is dry and gone to seed.I mowed today with it after everything was put back together and it ran the coolest it’s ran in summer temps for a long time so I think it’s fixed.
Check the Spark Plug gap, tooYeah, just adjust the carburetor screws for a richer mixture, raise the float level, and/or clean out the main jets.
Make sure the throttle plate isn't sticking open. too.![]()
The Brits had Lucas Electrics, inventers of the self-dimming headlight and intermittent wipersI read that the Brits say the aluminum & plastic
radiators are throw aways and some other
Brits said K-seal works great for fixing leaks
willy
Not a bad idea. How I used to blow out the cab of my truck.It has air brakes and I often wonder about plumbing an air hose into it, put a coupler on end of hose and clicking in a long wand to blow out the rads.
