Kubota F series
   / Kubota F series #291
For those who have had the F series, how have they fared over time?
Has anyone had the opportunity to compare the F series mower with a Ventrac for mowing slopes sideways?
Thanks!
   / Kubota F series #292
I purchased my '09 F-2880 in late 2011 as an ex-municipal unit with about 1300 hrs of hard, but reasonably well maintained usage. It has about 1900+ hrs on it now and have replaced the starter and had a rear (steer) axle shaft break in hard use on a very steep property where 4WD is almost always being called on. I added 3 inch wheel spacers on the mains and fluid-filled them as well for added stability, and doubled the rear counterweight, but was very stable and good traction in stock form. Some of where I mow is 35+ deg. It will slide well before it starts to tip....fairly new turf-tires.
These F-Series Kubotas are very common with the municipal/councils around Australia, much more so than the JD, NH or others including Ventrack, so that says a lot....they are also Very expensive new, so second hand is only way I could have considered such a machine, but nothing less would work on my 4+ acres. If mine were to totally die sudenly, I would get another....perhaps with 72" deck and few more ponies. Wish at times it had steering brakes, but parts are available to add them.
For additional versitility, I fabricated a tipping Carry-All that mounts in place of the 60" mower deck....swaps out in few minutes....also a 250 L (60 US Gal) fire tank w/Honda & 12v pumps & hose for ember attack in fire season....also swap out in a few minutes. A 30 L 12V spray tank mounts on the mower deck for weed control. Has a heavy duty aluminum canopy attached to the ROPS....fitting sunvisors to it soon for these low-sun-angle winter days.
Cheers from way-downunder Tasmania
   / Kubota F series #293
Thanks for the reply.
Are you saying you mow 35+ degrees sideways? That’s amazing!
   / Kubota F series #294
I usually do those 35 deg slopes downward, but have done them up....and turned around mid-slope. Routinely do 25 to 30 deg sideways though....but can still side-slip bit more than I like at times (damp or very dry grass) ....the main parts (75% of which are quite steep with 20 to 30 Deg sections) I do closing-the-square (so blowing out), so get to deal with all angles from all directions. Experimented all ways on the very steepest section when I first got this machine and before any mods....satisfied that Could Do everything....but bit more peace-of-mind (and for the wife, who still does not like to watch me on 'Bracken-Fern Hill') with the 6" wider main-track, loaded tires, and more counter-weight. Several friends tried to talk me into sheep....and others still hardly believe I actually Mow the steep hill.
Do not tell anyone, but I also bypassed the seat safety-switch....going down the steep slope one's butt gets light on the seat and can (has) shut down the engine....and of course also the HST....not a good feeling as the brakes on my machine are mainly for parking, not smooth controlled desent from near-panic mode! I also engage the diff-lock and locked-4WD mode to maintain full control. I am quite safety consious, but keeping the engine/trans running is safer than shutting off!
These Kubota F-Series are great commercial-duty mowers....but mainly just mowers....(they do have a snow-blower and snow/leaf rotary brush available)....and as you have probably figured, can tackle much more severe terrain than any ZTR. The Ventrac machines are more multi-purpose with a range of factory attachments.... but still great for steep terrain... with dual wheels....both quite $$$$ new....would seriously factor in local service & support in your ultimate decision.
Back in Colorado I had an articulated PowerTrac 1845 for our very steep property there (see a pattern?)....and seriously considered shipping it down here, but few of the attachments I had for it would have been useful here....and I did NOT have a mower head....so sold it with that place and got the Kubota for here. That PowerTrac is sold as a commercial Slope Mower and rated to 40 Deg with dual wheels F&R. Mine only had the foamed-singles, but had 3" wider track front & rear. Only factory-direct with no local dealers or service, but is really only an engine (Duitz) and hydraulics... and lots of heavy steel plate....very few special parts.
Cheers, Rip
   / Kubota F series #295
Cheers, Rip
Thanks a lot, Rip, for all the details! Appreciate your time.
   / Kubota F series #296
F Owners who also have/do run a zero turn:
I have a unique, large customer property I am admittedly doing some damage to by a zero turn with bar tires. Turf tires will not hold on the hills. The property is steep and there are a decent amount of trees to cut under. On top of that, the turf is mostly weeds and grass mixed, so the root system is not all that strong. I’m getting a smattering of complaints about tire marks.
Is an F the answer to my needs? I missed out on a chance to get a 3680 72” last year.
Over the winter, should I make the switch?
   / Kubota F series #297
I'm well pleased with my old F2000 that I purchased well used. It still mows well and the 4wd will walk it up most slopes and also mow sideways on them.
The steepest that I mow is about 26-28 degrees, mine only has a grab handle on one side I keep thinking about adding one to the other side,
for now I just lean over and grab under the fender. rhinohide canopyleft side .jpg
   / Kubota F series #298
for now I just lean over and grab under the fender.View attachment 661271
Any trouble in tall or thick grass ?
Not tippy sideways on steep slope?
   / Kubota F series #299
I have a 72"side discharge deck, in tall or heavy grass it will leave a windrow at times,
Mine I can't find the gator mulching blades so it does leave a visible residue at times.
The mower seems to be more comfortable on slopes then I am,
I added the rops when I bought it as it seemed to have no issue traversing side slopes that I have a bit of a pucker factor with.
I tend to run in 2wd when side hilling as I would expect the uphill tire to warn me a bit by spinning..
I mow at a low speed quite often as I am on rough ground with rocks and lots of tree roots that are half out of the ground.
   / Kubota F series #300
Is an F the answer to my needs? I missed out on a chance to get a 3680 72 last year.
There are several front deck mower brands, and I recommend four wheel drive.
Mine is a Toro 328D with a tractor canopy that I added 5 years ago:
Enmark Z Spray (A53316)
Enmark Z Spray...
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
John Deere skidsteer (A55788)
John Deere...
Terms & Conditions of Auction (Payment Terms) (A59213)
Terms & Conditions...
