Kubota F2680e 72" side discharge compared to ZD326 60" rear discharge
   / Kubota F2680e 72" side discharge compared to ZD326 60" rear discharge
Having gone from the ZD326 to F3680, the ring of no grass around my landscaped trees is now disappearing using the F. Does the F trim as close, no, but does less damage to the grass. And the F is fast. Cut 25% off my mow time.
My F at home cuts as close to the trees as the Z but I have to make a couple of passes at it. I can cut about 3/4ths of the base up against the tree and then pick up the other 1/4th on a different pass or do a back and forth. The Z rollbar hits the lower limbs so I can't get it up to the tree for the full circle. A tree with high limbs is easier with the Z doing the one circle pass. Two great machines but if I had to just have one it would/will be the F3080.
2004 FREIGHTLINER CST120 (A58214)
2004 FREIGHTLINER...
2021 Kubota SVL 97-2 Skid Steer (A57148)
2021 Kubota SVL...
2014 Kenworth T370 Single Axle Dump Truck, VIN # 2NKHHM7X6EM419999 (A57453)
2014 Kenworth T370...
2026 Quality Steel 8ft S/A Utility Trailer (A56859)
2026 Quality Steel...
UNUSED SDLANCH SDLJC HIGH-END MOBILE JAW CRUSHER (A58375)
UNUSED SDLANCH...
SUV (A59231)
SUV (A59231)
