Loading the rear tires simply doesn't allow you to get near rated maximum lift....because it can't. In this example Kioti says you have to put 1,047lbs on the 3pt to max the loader. Putting weight on the 3pt takes weight off the front axle, by using the rear axle as a fulcrum/pivot point. Making the pivot point heavier (loading the tires) does very little to take weight off the front axle. Think of a teeter-toter with the rear wheels being the pivot. If you have a fat kid on one seat, you need another fat kid on the other seat....no real way around it.
My loader is rated at 2,639lbs max lift at the pins, to full height. With pallet forks on, I was barely able to lift the 1,300lb (weighed) slab that became my counterweight. Add the slab, and forks, and it was probably 1,700lbs total load, give or take. The rear tires were extremely light, and came off the ground with sudden loader movements or sharp starts/stops of the tractor.
Everybody likes pics....1,300+ lbs after it was finished (added the legs, drawbar, top link etc).
I'll have to check it out for myself, I've got 1164bls of ballast in my rear tires and I have the hoe on it that I have not taken off yet, she's a hefty girl right now.
There are alot of folks out there that say they have loaded tires, but in reality there is hardly anything in them, I'm not saying that is your case.
Thats just been my experience the 30 years I spent in the field as a tire guy. Alot of folks just don't know that they got screwed when they paid to have their tires filled.
I won't know for sure until try it myself with the backhoe off, you may be right, but I'm a check it out for myself kind of guy.
This is off of Kiotis Brochure for the loader, It doesn't say the weight has to be on the three point.
It just says counter ballast 1048lbs.
Loader Specifications
Model KL401
Counter Ballast 1,048lbs (475kg)
A Maximum lift height to pivot pin 107.8 (2,738mm)
B Maximum lift height under level bucket 105.5 (2,680mm)
C Clearance with bucket dumped 79.9 (2,029mm)
D Reach at maximum lift height 16.1 (409mm)
E Maximum dump angle 73 ー
F Reach with bucket on ground 73.6 (1,869mm)
G Maximum rollback angle 30 ー
H Digging depth -6.7 (-170mm)
J Overall height in carry position 52.7 (1,339mm)
L Depth (Horizontal distance) 20.7 (526mm)
MHeight (Overall vertical height) 22.6 (574mm)
N Length (Horizontal distance) 25.9 (658mm)
Lift capacity to maximum height at pivot pin 2,761lbs (1,252kg)
Breakout force at pivot pin 3,727lbs (1,691kg)
Bucket rollback force at ground line 4,633lbs (2,101kg)
Relief valve setting (Loader control valve) 176 bar (2,556psi)
Rated flow (Tractor hyd. system) 10 gpm (38ℓ /min)
Attachment (Bucket size) 72 (1,829mm) (QA)
KIOTI Utility Tractor
Loader Model : KL401 Tractor Model : DK40SE/DK45SE/DK50SE
Front End Loader
The KIOTI KL401 front loaders are specifically designed for
the DKSE series tractors, providing efficient performance
with single lever joystick control. The KIOTI loader with
quick attach bucket is designed to be easily attached and
detached.
Items 1,500 / 2,000 / 2,600rpm
Raise boom 7.6 /5.7 / 4.5
Lower boom 4.9 / 4.8 /4.7
Dump bucket 2.2 /1.9 /1.5
Retract bucket 2.3 /2.2 /2.1
Loader model KL401
Specifications and design are subject to change without notice.
