Kubota Headlight Bulbs
   / Kubota Headlight Bulbs
Ah yes one of those!!
I did put in higher wattage bulbs in my B3200. Went from 35 to 50 watt with no ill effects. Not sure what your lights are like. You might have a time finding lights to fit those sockets.
The only place I was able to locate a similar bulb with that goofy flange, was on ebay with a site in England and they sell bulbs for Motorcycles.
I went ahead and ordered two 35/35 watt bulbs and I can try them and keep checking the temperature when I install them to see if the plastic lens gets any hotter than with the oem 15/15 watt bulb.
I have always been disappointed by the light output of the headlights on the B2150.
In addition to ordering these 35/35 bulsb, I just completed an alternator upgrade ( to 40 AMP ) and have some LED worklights to install.
I need to light almost exclusively for nighttime snow blowing with my rear blower, but if I have better li[ght, I may be incluined to finish cuttint grass in the summer even after it gets dark.
It's been a real challange to do anything in the dark with the stock lights.
Thanks, Tim
   / Kubota Headlight Bulbs #12
Thanks, Tim
I doubt the higher wattage will be a problem unless your bulb come close to the lens. And yes Kubota headlights leave a lot to be desired.:D
Thanks...! I'll report back on how it works out.
Regards, Tim
   / Kubota Headlight Bulbs #14
I solved the poor headlight problem on my B7200. I went to Tractor Supply and bought two accessory lights and took the Kubota lights out and made new brackets to hold the new lights where the Kubota lights were. They work great, and I have been using them for 15 plus years without a problem. There has not been a problem with the lights drawing too much from the battery.
The factory lights on my B2410 are very good, but the B7200 had really dim lights.
KubotaEd
   / Kubota Headlight Bulbs #15
KubotaEd
Have any pictures so I can see the light installation on the B7200? Does it look "factory" with the hood closed?
   / Kubota Headlight Bulbs #16
I'm sorry I don't have any pictures, but the lights I installed sit under the hood excatly where the old lights were, and I don't think anyone would be aware that they were not the lights that came on the tractor. They fit up tight against the headlight openings and the modifiacations I had to do were just to construct brackets to hole the new lights in place. I had to make the brackets because the new lights were thicker than the original ones.
They look good, and work wonderfully.
I know it's a pretty old thread.... but I wanted to let everyone know that I did put the 35/35 watt bulbs in to replace the 15/15.
But I am paying the piper now..... I just spent $180 to replace BOTH headlight assemblies because the added heat from the higher wattage bulbs did, in fact, melt the plastic.
It took a while, but it melted the plastic enough that the bulb contacts were not aligned properly in the socket and kept blinking off and on.
So I will be putting in my new headlight assemblies and keeping the oem bulbs.
I bought 4 really good LED lights which make up for the poor lumen output of the oem lights.
I bought the "Rigid" Dually driving lights. And they do the trick without a lot of amp draw.
Although, I did do the alternator upgrade so the Amp draw was not a huge concern anyway.
   / Kubota Headlight Bulbs #18
Right about the heat... You May get away with it during the Cold winter mths... but summer will cook you.
Only way to Increase the lighting a Lot without generating a Lot of heat is to find a LED replacement lamp.
I keep searching for an LED that will fit, but so far.... no luck.
I did get 4 RIGID LED work lights that put out a lot of light. So I've ordered and recvd a new set of headlights with the oem bulbs in them.
Until an LED bulb becomes available, I'll be leaving the original bulbs in place.
Thanks.
   / Kubota Headlight Bulbs #20
I'd be interested in your feedback when the LEDs arrive. I wanted to upgrade but am not sure now. I understand that lights rely on the accurate position of the filament to throw the light. As an LED emits light from a number of points all over the place the light doesn't go where intended by the designer of the reflector/lens. Apparently it is not uncommon for the light to look brighter, but performance to actually be worse.
8 Ft Fork Extensions (A50322)
8 Ft Fork...
2015 John Deere 8345RT Track Tractor (A50657)
2015 John Deere...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
19009 (A48082)
19009 (A48082)
2012 Chevrolet Traverse SUV (A50324)
2012 Chevrolet...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
