Kubota HST Leak at Split Pin Drain/ Clutch Housing
   / Kubota HST Leak at Split Pin Drain/ Clutch Housing #1
evanjohnson
Coastal SC
KUBOTA L4610 HST/ JD 955 (SOLD)
I have a Kubota L4610HST with approx. 350 hours.
It worked fine the last time I used it but when I went into the garage it looked like it peed hydraulic fluid.
It looks like it's coming from the split drain plug on the clutch housing.
Anyone have any ideas?
Thanks,
Evan
   / Kubota HST Leak at Split Pin Drain/ Clutch Housing #2
If it is hydraulic oil for sure it means the input shaft seal to the tranny has woofed its cookies. This would require a split and new seal installed.
My L5030 weeps out this hole, only a drip every so often. I don't know if it is from the tranny or engine side though.
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
2009 Ford F-350 4x4 Flatbed Truck (A51692)
2009 Ford F-350...
Payment Terms (MUST READ) (A50775)
Payment Terms...
