Kubota HST Leak at Split Pin Drain/ Clutch Housing
   / Kubota HST Leak at Split Pin Drain/ Clutch Housing #1
evanjohnson
Coastal SC
KUBOTA L4610 HST/ JD 955 (SOLD)
I have a Kubota L4610HST with approx. 350 hours.
It worked fine the last time I used it but when I went into the garage it looked like it peed hydraulic fluid.
It looks like it's coming from the split drain plug on the clutch housing.
Anyone have any ideas?
Thanks,
Evan
   / Kubota HST Leak at Split Pin Drain/ Clutch Housing #2
If it is hydraulic oil for sure it means the input shaft seal to the tranny has woofed its cookies. This would require a split and new seal installed.
My L5030 weeps out this hole, only a drip every so often. I don't know if it is from the tranny or engine side though.
JOHN DEERE BACKHOE FORK ATTACHMENT (A53843)
JOHN DEERE BACKHOE...
2015 CATERPILLAR CT660 TANDEM AXLE DUMP TRUCK (A54313)
2015 CATERPILLAR...
TMA (A49461)
TMA (A49461)
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
2015 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2015 GENIE...
