Artisan
Veteran Member
A- Don't listen to me
B- Don't disconnect a hose directly after a pump and deadhead it w/ a gauge, BAD things "can" happen.
C- You should be OK if you disconnect a hose right at a cylinder because you are after the valve and the valve should have a pressure relief on it.
D- Refer to "A"
Guys do this every day, it's easy, go out on a limb and LEARN, make your
own gauge to start, figure that part out and take a picture of it for us. your
NEVER going to be able to do this stuff yourself till you grow a pair and just
do it, and I say that not being mean. Heck I used to say the same stuff,
then I grew a pair...
Now I am welding and making stuff and making
hydraulic hoses and grapples and this and that, you need to just do it, you
will loose a couple battles but you will win more than loosing and each time
you win you will be more confident. Plus you will save a pant-load of $.
Take a pic of your tractor and a clear pic of the hoses in the area you want
to test, you will get some help here...pics work best here. IMO.
Refer to "A" :laughing:
D- Refer to "A"
