Kubota issue with high idle/ running rich
   / Kubota issue with high idle/ running rich #1
Mitch01
ottawa
kubota
I have a kubota compact dump loader model KC51
With a small gas Kubota engine model GH170-1-E2-GCLY
It has a mikuni carb
When I inspected the machine I found that the thottle was seized wide open bad and the thottle cable was also seized and junk.
I have un-seized the thottle and replaced the cable and thottle control.
Now the machine runs rich?
I opened the carb and its very clean looks new.
Thought it was cause the air breather was off but nope it makes no differance.
I'm quessing it has to do with idle mixture/ fuel mixture but on these carbs theres retarted nipple things and only one top scew.
What is the default mixture and where are the mixture scews
thanks all info will help
   / Kubota issue with high idle/ running rich #3
Does the carb have a float? Is the float have a hole in it, or if its a foam float, has it soaked up gas and is to heavy? Is the float level set correctly? I'm just guessing here.
Hey thanks for the replys where is the repair thread? Things on this site are hard to find and i keep geting attacked by malware when entering this site?
and the float is plastic no holes you cannot set these floats.
   / Kubota issue with high idle/ running rich #5
I noticed that you posted in the Parts and Repairs Forum. Best wishes. BTW, Welcome aboard.
   / Kubota issue with high idle/ running rich #6
Welcome.
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
2013 Ford F-450 Dump Truck (A59230)
2013 Ford F-450...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
2018 INTERNATIONAL 4300 NON CDL 26FT BOX TRUCK (A59904)
2018 INTERNATIONAL...
