KUBOTA L3710--AIR FILTER LIGHT IS ON
   / KUBOTA L3710--AIR FILTER LIGHT IS ON #1
rmccutch
AIR CLEANER LIGHT CAME ON. I CHANGED FILTER. LIGHT IS STILL ON. IS THERE A WAY TO RESET OR TURN OFF THE LIGHT?
   / KUBOTA L3710--AIR FILTER LIGHT IS ON #2
Most likely you have a bad switch. Did you change the inner and outer elements?
   / KUBOTA L3710--AIR FILTER LIGHT IS ON #3
The same thing happened to me a couple of years ago. There is a small sensor screwed into the air filter housing. The replacement is under $20 and it only takes a few minutes to swap it out.
In 500+ hours and 6 years that sensor and 2 tire tubes are the only parts I've replaced, (other than fluid and filters).
NO. I JUST CHANGED THE OUTER. THE INNER LOOKED FINE.
   / KUBOTA L3710--AIR FILTER LIGHT IS ON #5
Thread moved to Kubota forum.
rmccutch - I think your CAPS key is stuck. /forums/images/graemlins/grin.gif
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A54865)
2014 Ford F-150...
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A55788)
2017 Ford F-350...
New/Unused Easy Clean Hot Water Pressure Washer (A54865)
New/Unused Easy...
2018 WACKER NEUSON RTSC3 ROLLER (A54607)
2018 WACKER NEUSON...
2011 John Deere 120D (A47477)
2011 John Deere...
(APPROX. 15) UNUSED IRANCH GROUND PROTECTION MATS (A54757)
(APPROX. 15)...
