KUBOTA L3710--AIR FILTER LIGHT IS ON
   / KUBOTA L3710--AIR FILTER LIGHT IS ON #1
rmccutch
AIR CLEANER LIGHT CAME ON. I CHANGED FILTER. LIGHT IS STILL ON. IS THERE A WAY TO RESET OR TURN OFF THE LIGHT?
   / KUBOTA L3710--AIR FILTER LIGHT IS ON #2
Most likely you have a bad switch. Did you change the inner and outer elements?
   / KUBOTA L3710--AIR FILTER LIGHT IS ON #3
The same thing happened to me a couple of years ago. There is a small sensor screwed into the air filter housing. The replacement is under $20 and it only takes a few minutes to swap it out.
In 500+ hours and 6 years that sensor and 2 tire tubes are the only parts I've replaced, (other than fluid and filters).
NO. I JUST CHANGED THE OUTER. THE INNER LOOKED FINE.
   / KUBOTA L3710--AIR FILTER LIGHT IS ON #5
Thread moved to Kubota forum.
rmccutch - I think your CAPS key is stuck. /forums/images/graemlins/grin.gif
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2020 Club Car Onward HP Li ION Electric Cart. (A55758)
2020 Club Car...
UNUSED IRANCH 15" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 15"...
2025 Swict 84in Bucket Skid Steer Attachment (A55787)
2025 Swict 84in...
KUBOTA L2501 TRACTOR (A54756)
KUBOTA L2501...
UNUSED 30PCS Brown Metal Roof Panels (A53117)
UNUSED 30PCS Brown...
