KUBOTA L3710--AIR FILTER LIGHT IS ON
   / KUBOTA L3710--AIR FILTER LIGHT IS ON #1
rmccutch
AIR CLEANER LIGHT CAME ON. I CHANGED FILTER. LIGHT IS STILL ON. IS THERE A WAY TO RESET OR TURN OFF THE LIGHT?
   / KUBOTA L3710--AIR FILTER LIGHT IS ON #2
Most likely you have a bad switch. Did you change the inner and outer elements?
   / KUBOTA L3710--AIR FILTER LIGHT IS ON #3
The same thing happened to me a couple of years ago. There is a small sensor screwed into the air filter housing. The replacement is under $20 and it only takes a few minutes to swap it out.
In 500+ hours and 6 years that sensor and 2 tire tubes are the only parts I've replaced, (other than fluid and filters).
NO. I JUST CHANGED THE OUTER. THE INNER LOOKED FINE.
   / KUBOTA L3710--AIR FILTER LIGHT IS ON #5
Thread moved to Kubota forum.
rmccutch - I think your CAPS key is stuck. /forums/images/graemlins/grin.gif
ASSET DESCRIPTIONS & CONDITION (A54313)
ASSET DESCRIPTIONS...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55218)
Galvanized...
2008 Ford F-250 Reading Service Truck (A55788)
2008 Ford F-250...
2006 Chevrolet Impala Sedan (A55853)
2006 Chevrolet...
2019 BOBCAT S770 SKID STEER (A52705)
2019 BOBCAT S770...
