Kubota L3901 4X4 HST VS GST Transmission
   / Kubota L3901 4X4 HST VS GST Transmission #11
Well that certainly clears it right up!
   / Kubota L3901 4X4 HST VS GST Transmission #12
   / Kubota L3901 4X4 HST VS GST Transmission #13
Taken from “New Features of the kubota Grand L30 Series Compact Tractors”
The Glide Shift Transmission (GST) is original Kubota technology which provides 12 forward and 8 reverse shift-on-the-go gears without the need for clutch operation. The GST has a hydraulic clutch and transmission gears that are changed by the action of an actuator located in the transmission. When the operator initiates a gear change, the GST automatically performs a series of operations that includes disengaging the hydraulic clutch prior to the gear change, changing the gears and then engaging the hydraulic clutch after the change.
The ECU allows for a single shifting lever that actuates a potentiometer signifying the specific gear selection. In the Grand L30 series tractors, the ECU controls a proportional pressure reducing valve, solenoid valves, and performs a gear change by operating a hydraulic clutch.
With this GST system the pressurization of the hydraulic clutch can be set by a proportional pressure reducing valve for limitless stages, all of which is controlled by the ECU. The tractor is equipped with an engine tachometer sensor and a travel speed sensor, as well as a potentiometer that distinguishes the position of the gear selection lever. Based on digital signals from the engine tachometer sensor and the potentiometer, travel speed after the completion of a gear change is calculated, while the travel speed sensor calculates the actual travel speed. Based on the difference between the two speeds, the pressurization characteristics of the hydraulic fluid supplied to the clutch is set. Thus the Kubota GST brings about a smooth gear change by changing the pressurization characteristic in response to the various patterns of gear operation.
Acceleration of the tractor is calculated based on digital signals from the travel speed sensor. Under conditions when the tractor accelerates rapidly, the pressurization is changed to become slower during the pressurization process. When the tractor accelerates slowly, the pressurization is changed to be more prompt.
After the hydraulic clutch begins engaging and the acceleration of the tractor starts, the acceleration is calculated and the pressurization characteristic is compensated. Tractors may be equipped with a variety of different implements according the context of work users wish to perform. In particular, when an extremely heavy implement is attached to the tractor, acceleration does not occur until the compensation begins, which makes gear change time much longer. Therefore the compensation of the pressurization characteristic based on the total tractor weight is realized. The offset can be input using the “Adjustment Mode” of the IntelliPanel, with the correct offset stored in ROM. The ECU of the GST takes in the correction value by communicating with the ECU of the IntelliPanel and compensates the pressurization characteristic. The offset is just a derivative of the diameter of the tractors tire diameter.
   / Kubota L3901 4X4 HST VS GST Transmission #14
To the Original poster, the L3901 does not have a GST transmission available as an option, so none of this applies.
   / Kubota L3901 4X4 HST VS GST Transmission #15
If it is hydrostat info you need, then tell me do you want to learn about Kubota hydrostats?. There are two.
in the standard L series is a standard hydrostat, in the Grand L series there is hydrostat +. A much more full featured hydrostat. Lemme know and I can answer questions about both of those.
   / Kubota L3901 4X4 HST VS GST Transmission #16
I am a bit surprised nobody has asked the OP what he actually plans to use the tractor for!! And I'm surprised the OP is not factoring that into his decision!!
For Agricultural use or just mowing, manual transmission is a great option. That implies you are not changing direction, speed, or gears often during that work, if at all.
If you plan to do loader work, landscaping, grading, or anything else involving a lot of back and forth or speed/gear/direction changes, go with HST. As an example, if you will be moving dirt or other materials with the front loader, you will be *way* more efficient with HST. It gets slow/cumbersome manually clutching and shifting gears for that type of work.
Budget is always a factor, but that should not be a driver between gear and HST. Let planned usage be the driving factor.
Hey Everyone,
I meant gear vs HST. Just the two options on the website for the 2014 3901. I thought GST meant Gear Shift Transmission. I am very new to this as you can tell.
"If you plan to do loader work, landscaping, grading, or anything else involving a lot of back and forth or speed/gear/direction changes, go with HST. As an example, if you will be moving dirt or other materials with the front loader, you will be *way* more efficient with HST. It gets slow/cumbersome manually clutching and shifting gears for that type of work."
S219, This is pretty much what I will be using the tractor for. Thanks for all the input. I think the HST is what I need.
   / Kubota L3901 4X4 HST VS GST Transmission #18
   / Kubota L3901 4X4 HST VS GST Transmission #19
Hey Everyone,
I think you will be very happy, particularly since it's not actually GST vs HST. Those plain manual transmissions are a pain in the neck, and the primary reason I traded tractors (with a healthy dose of evangelizing from James K0UA, of course!) :)
   / Kubota L3901 4X4 HST VS GST Transmission #20
Well here is the thing.. He called the manual transmission in an L3901 a GST (glideshift) and it is not. The manual transmission in an L3901 is a syncro shuttle.. a very distant cousin to a true GST (Glideshift).. glideshift is a Kubota exclusive on the Grand L series and is a hydraulic shift pack that allows clutchless shifting between forward and reverse. Glideshift is a very complicated gear transmission. But a L3901 does not have one.
Did they change transmission on the geared 3301-3901? Because the 3200-3800 were non-syncro geared. Just curious.
2000 FORD E350 CUTAWAY BOX TRUCK (A52577)
2000 FORD E350...
2017 JOHN DEERE Z950M LOT NUMBER 86 (A53084)
2017 JOHN DEERE...
2009 VOLVO VNM DAY CAB (A52576)
2009 VOLVO VNM DAY...
1999 Ford LA-9000 Aeromax Godwin Steel Dump Truck (A52384)
1999 Ford LA-9000...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
