Except for the heavier Massey MF1758 and Kioti NX6010 or the more powerful Deere 4066R, that is.
Just saying'
Do any of them have dual speed hydro and stall guard? All those tractors with out a loader are within 150lbs off each other.
Just saying'
I have had an A/C problem with my JD 4720 and my dealer provided a replacement tractor in the form of a used Grand L5740. I couldn't be more impressed with the Kubota! It is head and shoulders above my JD4720 in strength and power, although not nearly as comfortable. I have considered the new L6060 and while I haven't completely ruled it out, I'm concerned that I will outgrow the CUT tractors in the next year or two. I'm getting opportunities to bid on work that involves significant acreage...20, 30 acres or more, and I will need to get larger, heavier tillage and planting equipment, probably in excess of what a CUT machine 3 pt can handle. Of my current implements, most have 6'-7' working widths and the heaviest is a Kasco Eco Drill with three boxes that weighs in around 1800 lbs empty. On sidehills I have to be careful with the drill and also my Land Pride seeder. I think the bigger tractors will handle all of the equipment better in these circumstances. I was leaning toward the 5075E because it is just slightly smaller, lower profile than the M7060...and it's less expensive. Some of what I've read has me a little spooked about the John Deere 50xxE series.
Don't get me wrong, I LOVE my hydro. LOVE it. That said, for tilling and planting 20-30 acres at a time, it's not the right tool for the job in my opinion. The efficiency loss of the hst would be too much I think.
That said, one could buy a big hydro CUT for loader work and daily chores, and an older used gear tractor for the real Ag stuff. Something like an international 1066 or JD 4020, or maybe one size down. Just an idea.
Yes kubota offers adding a creeper range I believe it is a dealer install kit option like the 1000 rpm pto on the m8540/60 and up
Dual speed? No, each range (L-M-H) covers the same working speeds of Kubota's 2-speed range. When I looked at the L6060, the two-speed transmission felt like everybody else's single range with a shift point in the middle. The Kioti I purchased for example has a slightly faster ground speed in high range, so what is Kubota's two speed doing? FWIW, everybody has stall guard these days and every one of them is easier to make changes to things than Kubota's new, single button.
The dual speed allows you to do more work in any range. When the DS is in low it gives you more pulling power than a tractor that does not have a dual speed hydro because it is "geared" lower. With a tractor that does does not have a dual speed you would have to down shift to a lower range. With the DS in high you have a faster ground speed. The DS is about like a splitter on a truck transmission. I'm not sure how they rate the topspeed on tractors, I have GPSed mine and they run faster than what they say they should, even the Bobcat did.
Understood. But to me duel speed in high, felt like everybody else's high with a shift point in the middle. I did not try it in medium or low and neither did i load test.
