Kubota M6800 & New Holand 451 Cutter Problem
   / Kubota M6800 & New Holand 451 Cutter Problem #1
Mooreaud
I just recently purchased a M6800. I'm having a problem trying to attach a New Holand 451 cutter to it. We have had this cutter for many years using it on an older Massey 165. When I try to attach it to the Kubota the lift arms are not long enough to attach the cutter. We also own a Kubota L2350 which seems to have the same problem. Any suggestions out there?
Thanks,
Jeff /forums/images/graemlins/confused.gif
   / Kubota M6800 & New Holand 451 Cutter Problem #2
Maybe a picture would help?
Is the problem the lift arms aren't long enough to attack the cutter without the cutter hitting the back tires?
   / Kubota M6800 & New Holand 451 Cutter Problem #3
I have a Sperry New Holland 451 that has been on all 3 of my Kubotas. On older 451's the center link is adjustable for different size tractors. The rods have indents for the bolts that hold the cone stops. Maybe the center frame needs to be adjusted shorter for the Cat I/II 3ph ? Lift cable would need adjusting too, I think.
As always, prompt cheerful refund if info is bogus
I'll try to get a picture. Yes, the problem is the unit hits the back tires.
Thanks,
Jeff
Thanks, I try that.
Jeff
I meant, I'll try that.
Jeff
   / Kubota M6800 & New Holand 451 Cutter Problem #7
I have a M6800 and use a NH 451 on it. NH makes a top link extender for the mower to make it work that cost around $100.00. This item is not hard to make if you have a welder and torch as I made mine. The funny thing is the mower want work on the new New Holland tractors either without the toplink entension. It works on my 3600 Ford and John Deere 5210 without the toplink entender. Call the New Holland dealer and they will fix you right up.
That's great info. Thanks for the reply. What part of SW Virginia are you in? I'm in Buena Vista.
Jeff
How long is the top link extender? It sounds like something I could make. Any pictures?
Thanks for all the help.
Jeff
2011 BMW 750 Li Sedan (A45336)
2011 BMW 750 Li...
2016 Dodge Charger Sedan (A44572)
2016 Dodge Charger...
More info coming soon! (A44572)
More info coming...
2010 UTILITY 53X102 DRY VAN TRAILER (A43004)
2010 UTILITY...
2017 INTERNATIONAL 4300 26FT BOX TRUCK (A43004)
2017 INTERNATIONAL...
New/Unused Self Dumping Hopper (A44391)
New/Unused Self...
