Kubota M7060
   / Kubota M7060
Quick search of all the big brands:
Gives me 3 good choices...
Rhino Turbo 96, 3ph, up to 2 1/2" capacity, 2,000 lbs
Kodiak HD8, 3ph, up to 3", 1250 lbs (seems light)
Bush Hog 3008, 3ph, 2" capacity, 1757 lbs
With difference in weight and capabilities, Rhino Turbo may be the way to go?
   / Kubota M7060 #63
Opinions on this 8' lift super duty Rhino? Seems to be well built and offer great cutting capacity for a multi spindle lift style cutter.
i have the 8' rhino turbo model, purchased several yrs back. not sure if that model is still avail. double walled top deck. @ 2000 lbs heavy duty in every respect. bush hog has something similar. probably land pride though not for sure.... considering your investment, go heavy duty whatever you get. believe the 7060 could handle it, but if you are on slopes, may consider suitcase ft weights. loaded rears of course. some have even loaded the ft tires, although kubota does not recommend (subject for another debate) just remember to gear down in heavy growth in whatever you choose!....we're now talking substantial investment & weight for transportation. know it must be a tough decision....wise to sleep on it :thumbsup:
btw think you are wise in considering twin spindle in whatever you decide on....also agree w/tripleR 3pt hitch lift is the way to go over drag model.
and yes, kodiak seems very light boasting 3" diameter cut.
   / Kubota M7060
The weight totals is the main thing that keeps coming up... I think that knocks the mahindra out of the running... Too heavy if that's possible.
Kubota 7060 may be the winner...
8 speed or 12?
Going to start shopping hard for the 7060 around me...
Thanks again!
   / Kubota M7060 #65
8 speed or 12?
Thanks again!
by all means, imho go with the hd 12 sp op on the 7060. not only will it give you more variation on ground speed, but also 3ph lift capacity. with that investment, you'll thank yourself in the long run. glad i did it for my 8540. & of course, hyd shuttle is a no brainer. best regards.
also if you go w/rhino turbo, use 85/140 wt gear oil per their recommendation
   / Kubota M7060 #67
Yep, no question go for a 12/12.
   / Kubota M7060 #68
12x12 Hyd shuttle for sure. I been running the 8x8 sync for several years and I should have listened to Triple R on the last 7040 I got and got the Hyd shuttle,especially for me working in the hay field,I know it would make moving/loading hay a lot better.I have the 12x12 on my NH and just so much better gear selection to find that right one,for what your doing. If resale later those two options will help it also.
   / Kubota M7060 #69
I prefer a 6x2, rather than a 4x3 too.
   / Kubota M7060 #70
The 7060 (or 6060 for that matter) would be more than capable of handling an 8' twin spindle. Our family uses a M5140 to pull an LP RCR2596. It does fine even in heavy cutting. We also have a Woods DS96 8' cutter and prefer it over the LP.
2016 Peterbilt 567 Tri-Axle Dump Truck (A50323)
2016 Peterbilt 567...
2016 Ford Explorer...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
1991 Great Dane 48' Reefer Trailer (TITLE) (A50774)
1991 Great Dane...
2015 Kenworth T400 T/A Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
