kubota mid pto hp rating?
   / kubota mid pto hp rating? #1
RoyBrooks
Ontario, Canada
Kubota/B7500,4WD,Hst
I have a b6200 with the mid pto, I was wondering if it would be rated at the same hp as the rear pto? I have a vickers v20f hydraulic pump and was thinking of running it off the pto to run a log splitter. The specs say the v20f I have puts out 6gals/min @1200 rpm, I calculated at 540 rpm the pump would put out only 2.9 which is less than the tractor. The mid pto has a speed of 2400 which the pump would put out about 11 gals/min much quicker. Was wondering about rigging up the pump to the mid pto , any ideas what the mid pto is for? besides the mower deck? /forums/images/graemlins/crazy.gif
   / kubota mid pto hp rating? #2
</font><font color="blue" class="small">( , any ideas what the mid pto is for? besides the mower deck? )</font>
CAUTION: A lot of my post is recalling information from memory; I don't have the information readily available to validate any of it...
MID-PTO INFORMATION:
I vaguely remember reading in one of my manuals that Kubota's mid-PTO is to be used only for specific Kubota implements. I can't remember which implements can be used (besides the mid-mower), but it seems like maybe the front mounted sweeper? You might want to check to see if the rear and mid PTOs use the same spline; I think that they're different.
REAR PTO INFORMATION:
My older B7100 had 3 rear PTO speeds (I think the newer hydrostat B7100s have only 2 PTO speeds).
My B2150 has two PTO speeds for the rear PTO. I think that the higher PTO speed is in the 800 rpm range.
I believe that the B7200 was produced in the late 1980s (between my two tractors). Therefore, even though I know very little about your B7200, I would guess that it probably has 2 (or more) rear PTO speeds.
Hope that this was helpful (and accurate...),
Kelvin
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2011 Hyundai Sonata Sedan (A51694)
2011 Hyundai...
Land Pride RCF2072 (A50123)
Land Pride RCF2072...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
