Ford tractor
Platinum Member
- Joined
- Apr 7, 2010
- Messages
- 973
Out of curiosity, did you try to have a radiator shop replace the broken bottom tank with a metal one? I would have tried that.
Ford tractor said:Out of curiosity, did you try to have a radiator shop replace the broken bottom tank with a metal one? I would have tried that.
No, I didn't. The nearest one is about an hour's drive away.
I have to disagree with that. 10 to 20% of the resin is iron powder. I found that out when I was trying to attach a Neodymium magnet to an aluminum plate with JB weld. I put a big blob on the plate and when I set the magnet down the JB weld started moving toward the magnet.
It's listed in section 15 of the MSDS.
http://jbweld.net/techinfo/MSDS Weld Resin Jan-11.pdf
On the new style radiators the core is aluminum with a seal between the plastic tank and the core. They crimp them together, usually with "fingers" on the aluminum core bent over. You would need to straighten them and recrimp them after replacing the lower tank. Most Aluminums doesn't like to be straightened out then bent a second time.
I have heard there are some special glues designed for plastic radiator tanks but I don't know of any specifically. Now that it has JB weld on it I doubt that any other glue will work. The JB weld may work great, never tried it.
Like I said before, we're a throw away society. The idea of going to a radiator shop to sweat on a new tank or replace a plugged core is a thing of the past. Now it's easier and more profitable to make a radiator that can't be fixed.
