Kubota, New Holland, Kioti, can't decide which one
   / Kubota, New Holland, Kioti, can't decide which one #11
Re: Kubota, New Holland, Kioti, can\'t decide which one
Hello, the capacities used were for the implement pump based on the charts at compact tractor reviews websight. One can go there and click on the home page where theres a comparison of 30Hp tractors in the link in the lower right corner. The Kubota does have 13. 2 total, and lists 8.3 for the implements and 4.9 gpm for power steering. The TC33 uses 7.6 for implements and 5.1 for power steering. The Kioti only listed 1 pump ,12.7gpm, they also only listed one pump on their homepage, perhaps a ck30 owner can explain if there are 2 pumps or 1. Also the hst comparisons on PTO horsepower listed the TC33 at 26.9hp the L3130 at 24hp and the ck30 at 23.5 hp. Matt
   / Kubota, New Holland, Kioti, can't decide which one #12
I utilize information from each brands website as well as the each brands printed material. I try to stick with first hand information.
In Kioti's printed material the CK25/30 is listed as having 'tandem' pumps with a maximum flow rate of 12.7 GPM. I have not come across a breakdown of the two pumps individual flow capacity.
Don
   / Kubota, New Holland, Kioti, can't decide which one #13
Don, you and I often disagree on things but I follow the specs the way you do, from the source.
I think the easy way to learn to do that is to go to the various tractor websites, some of the comparisions they give about their competitor don't seem to match up properly. I've seen some manufacturers "compare" thier tractor to models that were discontinued 2 or 3 years prior.
I also think that things like hydraulic flow don't tell the whole story. Just because one brand has more flow does not mean that brand can lift more. Hydraulic flow controls several things on the tractor, how the pumps are divided makes some difference that should be considered. However, when debating the difference between 12.7 and 13.2 I think they are, in the REAL WORLD, about the same to most of us users. I certainly would rather choose a tractor based on comfort and ergonomics rather than hydraulic flow.
Let's also be honest, it is difficult to make apples to apples comparisions because most of these machines don't really line up.
The TC33 and the L3130 are both higher HP than any of the others.
The TC29 and the CK30 actually do match up pretty well in relative size, features, capacities.
The (not mentioned in this particular thread) B2910 is also 30hp, but is a totally different animal is so many ways that it is not comparable.
The TC30 is not even in the ball game for a dozen reasons, but is the same HP.
So how, or better yet, why do we compare them? And all of us folks on TBN constantly compare them when we shop.
Honest almost Apples to Apples would be the CK30 & TC29. I think the TC29 probably loses that battle in most cases, especially when cost is factored in.
Dishonest Apples to Oranges would be the CK30 to L3130. No real comparison in capacity. Size & weight are very close, wheelbase is longer on the 3130. The L3130 wins that battle most of the time, despite the added cost due to its capacity and power.
Dishonest Apples to Oranges would be the CK30 to TC33. If PTO hp is a factor, there is no contest. Otherwise there is no reason for the added 3hp and the $$$ premium. CK30 wins for value, TC33 wins if PTO hp is needed.
Dishonest Apples to Oranges would be the B2910 to CK30. An ultra-light versus a tank. Two totally different machines that are designed for different work. Both share one commonality, they have 30hp engines. Who wins? Not even fair to say because it would be totally task dependant as to what machine to buy.
Dishonest Apples to Oranges woudl be the CK30 to the TC30. TC30, fine old workhorse, but it is so far below the CK30 in features that the winner is obvious.
Thanks for all the input. My present tractor, (the Ford 1600) is rated at 23HP PTO and I wanted to stick with this or slightly more. I realize the Kubota is obviously more tractor and probably more than I need. Really I'm just looking for something about the same size as what I have, only updated with power steering, FWD, and easier to get on and off. I have to consider my wife. I may look at the CK30HST today if the dealer has one. This appears to be the front runner after reading some of the comments on this forum. Great place for info, thanks to all. /forums/images/graemlins/cool.gif
   / Kubota, New Holland, Kioti, can't decide which one #15
Bob, in your opinion, what type of work are the B2910 and the CK 30 designed for?
   / Kubota, New Holland, Kioti, can't decide which one #16
<font color="blue">
Bob, in your opinion, what type of work are the B2910 and the CK 30 designed for? </font>
Divide tasks into 2 types: Constructing & Maintaining
Constructing TYPE tasks: digging ditches, logging, box blading, grader blading.
Maintaining TYPE tasks: mowing, spreading mulch, snow blowing, tilling a garden
Just my opinion, but an ultra light tractor like the B2910 is a great little estate tractor for maintaining the grounds. It is very small for the 30hp class of machines, and the lightest weight machine I know of (about 1/2 the weight of some of the heavy machines). Being smaller and lighter makes it a great lawn mower an with a 72" MMM it is a very hard tractor to beat at mowing, especially since its size lets it get into places that most other 30hp tractors only dream of fitting into. I feel the B2910 is great for "maintaining" and marginal at "constructing" the grounds.
Again, just my opinion, but the heavyweight CK30 would excel at tasks requiring the FEL or any ground engaging work like box blading, grader blading, etc. The 130 loader is far superior to the B2910's 402 in both capacity and visibility. The added weight gives it traction that the B2910 simply cannot match so blade work would be far more efficient wth the CK30. I feel the CK30 is great for "constructing" and marginal for "maintaining" the grounds.
Now all that said, both tractors can take a BH, both can lift with the FEL, both can mow the lawn. One is better suited for some tasks and the other is better suited for other tasks. I think both are absolutely excellent machines. I think the choice of one versus the other should largely be based on the long term tasks of the user rather than budget because both are 20 year investments so the price difference starts to fade away when spread over time. However what doesn't fade away is appropriate and efficient use. If I had small trees to mow up to, I'd pick the the B2910. If I had a mile long drive way that needed to be tended many times a year I'd pick the CK30.
Any tractor is a compromise. I think the best solution is to pick the machine that will "fit" the most long term tasks the best. Let me give you an analogy to hunting. Lets say you want to shoot a coyote or two, you'd pick a lightweight rocket like a 222 or 223, it shoots flat and with proper bullet selection you don't destroy the hide. But for deer hunting those cartriges are illegal in many states and realistically inadequate, so you jump up to a 30-30 and that works great. Then a black bear meanders onto your property so you pull out the 338 and he proptly is dispatched. And then your wife says YOU HAVE TO CHOOSE JUST ONE GUN for everything. What do you do? I'd suggest you compromise and pull out the trusty 308. Not the best choice for small game or large game but a reasonable compromise.
That is what I feel about tractors. Some folks NEVER mow their lawn with their CUT, other folks NEVER TAKE THE MOWER OFF their CUT. Pick the tractor that suits your LONG TERM tasks and that is the one you will be most happy with for the long time you are likely to own the tractor. Both the CK30 and the B2910 will mow the lawn, and both will fill your pick up bed full of heavy rock. If your weekly chores include a lot of hours of one task versus the other, then pick your machine accordingly. I think many people mis-pick their tractors and end up trading UP or DOWN in size 3 to 5 years after their initial purchase because they didn't look at the LONG TERM tasks.
   / Kubota, New Holland, Kioti, can't decide which one #17
Hello, Just in response that to somehow the information previously given about the 3 tractors specs was inaccurate or outdated... Go the the Kubota website for yourselves under their cometetive comparisons, The specs given were 100 percent accurate... Matt
   / Kubota, New Holland, Kioti, can't decide which one #18
Matt, I won't speak for Don's reply to your post, but I did agree with him. What I said is that I have seen inconsistent data on the comparison pages and that is why I pull the actual brochures and the spec pages for the specific tractors. Heck, I've even gone out and measured some of my own equipment. I don't think either Don or I were trying to argue, just to point out that sometimes even the manufacturers screw up their own data.
   / Kubota, New Holland, Kioti, can't decide which one #19
I think if you try out a CK30, you'll find that the platform operator's station is quite comfortable, and that all the controls are within easy reach. It's one of the easiest tractors to use that I've seen, and has plenty of power. Your wife, and you will enjoy the HST ease of operation as well. Of course the others offer the HST also. All of these tractors are very good, and you would probably be very happy with them.
DARGO: I find it interesting that you didn't mention that you had some pretty aggravating problems with yours. John
   / Kubota, New Holland, Kioti, can't decide which one #20
KiotiJohn, "pretty aggravating" is being awfully kind. You are certainly correct. And, I believe you are aware that I am keeping an eye on the options available on the DK65 as it evolves. I cut loose pretty hard on a green tractor and a blue tractor I owned previously to this shade of orange as well that gave me fits.
What I wanted, and still do, is a hydro tractor with a good cab, A/C, strong loader etc. The Kioti lineup is just starting to move into more of the "creature comforts" that I want in a tractor. They just don't have what I want in the size I want. As I mentioned before, when (hopefully not "if") the 65 series is available with hydro and in 4 cyl, I'll be the first to run out for a test drive. The power stats on the 65 are awesome. The 4 cyl engine just feels smoother to me and I want hydro.
Also, sort of off of the subject slightly, Consumer Reports now is rating the Korean made vehicles with the Japanese made vehicles on quality and reliability. A few years ago they were comparing them to the Yugo. /forums/images/graemlins/shocked.gif I think the Korean made tractors are just a couple of years away on the creature comfort part as compared to their Japanese counterparts. But, I don't think they have their eyes closed. /forums/images/graemlins/wink.gif
5011 Ford F550 (A55973)
5011 Ford F550...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55315)
2023 Kubota...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
flooring (A55758)
flooring (A55758)
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55315)
PENDING SELLER...
