Kubota Oil...A decision!
   / Kubota Oil...A decision!
A LITTLE MORE INFORMATION
I know this subject has been practically beat to death on this board, but I'll add a few more comments:
- 90 wt. in early 70's machines -
Back in the day, 90 wt. worked well in the machines because they were gear drive with a dry clutch and the 3 ph worked fine on 90 wt. If, however you installed a loader the 90 wt. really did'nt agree with the loader hydraulics.
UDT is alot more realistic for use with hydraulics. The only drawback with using UDT in the older gear drive machines is the transmission (main shaft) tends to spin longer after the clutch pedal is depressed causing a little bit of gear grinding when shifting. (less drag on the trans shaft and gears due to the lower viscosity of UDT). If I'm servicing an old gear drive without an added on hydraulic system (loader, front blade, aux hydraulics etc.) I use 90 wt. When servicing the latter, I use UDT. The only time you grind gears while using UDT is initially. If you hold the clutch in for a 10 count before the initial engagement, most of the time you'll get a clean shift.
- UDT VS. SUPER UDT-
First a little backround to show that Kubota is'nt the only one.
Before coming to my current dealership I worked at a John Deere dealer. Initially it was 90 wt. (same deal) Then it was universal tractor fluid (UTF) Then JD decided that their newer
machines would require Hygaurd (JD brand) after using Hygaurd for a few years it was determined that in colder climates "Low viscosity Hygaurd" was the way to go, which was much more expensive (double the price) than Hygaurd. Of course JD says if you're not using our fluid your warranty is void. (sound familiar so far?). Back to Kubotaland. A few years ago I was told by a Kubota tech rep. that use of regular UDT in everything other than GST tractors was O.K.
Even though tech data and owners manuals stated otherwise in some cases (all cases on the latest stuff). The rational for super in the GST's? In cold temps. on initial start up and engagement of the GST the clutch would'nt lock up for approx. 15 to 45 seconds with regular UDT. But with super you could crank and go.
Final thoughts:
In my shop UDT is $7.00 a gallon and super is $14.00 a gallon and when your changing a 10 gallon reservoir the money adds up quick. So is it a marketing scam copied from Deere? I don't know, I'm not an engineer. I have seen the difference in performance between the two in cold temps. GST's do take longer with UDT, HST's don't return to neutral as fast when cold. (not that HST pedal return performance is that good to begin with, with kubotas, but that's a whole nother can of worms). As far as getting different and conflicting answers from different dealers? I think the right answer is: If you're still under warranty use what Kubota tells you to use. (occasionally the Kubota rep asks for an oil sample)
After that I think the main concern is make sure your machine is warmed up good before you really start workin' it.
   / Kubota Oil...A decision! #12
Jon; Your logic is not flawed, if and only if Super-UDT is readily available. For many of us, it is not. It has to be ordered. So, the question comes down to, is the eventual cost (pain factor of ordering, paying more, and waiting) worth the risk?
Roy
Jon,
I can see your logic, however with a machine holding 10 gallons it adds up, oil changes are not at 1000 hours they are more like 400. And as for using the best, I have always been under the impression that length of the oil being in the crankcase is as bad as usage when you are talking years. That's got be a lot of condensation. All the things I've read say never leave oil in anything past 2-3 years no matter what. (feel free to disagree).
And I am in no way a tightwad or a maintenance skimper, I have my own hoist at home! What kind of maniacal devotion does that suggest?
What sticks in my craw is not the money, it is the fact that KUBOTA'S OWN DEALERS say this Super UDT is a waste. If they all said it's the cat's meow I'd being using 30 year old wine in the sump. They don't. (except for cold areas)
Kubota mech's post on his experience is right on the money and well written, at least from my talks with dealers. If I had a sit outside tractor or lived where it was cold I'd definitely be going "super" or true synthetic. That's the other thing that bugs me, everything else has a commercial equivalent, the "super" has no specs and no equivalent.
I'm ready to listen to the benefits of technology, even though I do still use one of those oil cans that you push on the bottom of to make oil come out!
del
   / Kubota Oil...A decision! #14
del,
This is way off the topic but I need to ask. Please,,,I'm nosy! I have read many posts posted by Del and am just wondering why you haven't registered or if you are registered under a different name? I will sometimes enjoy looking at a persons profile just for the heck of it. Oh well.....
On the topic FYI ----Just changed all the fluids in my L35 and used the UDT just because my local dealer only has this and doesn't carry the Super.....Like was mentioned earlier I get some time to do something and I can't just wait for oil to come in a day or two or weeks maybe next time I will order it way in advance just to make sure it's there when the time comes.
Darin
   / Kubota Oil...A decision! #15
Hi guys, When I purchased my new L35 my dealer instructed me to use the super UDT. He gave me this advice based upon some bad experiences he had on people trying to save money by using UDT fluid. Of course I do live in Syracuse, New York where it can be very cold.
Again, my L35 cost $34,000 I am not going to sacrifice my investment for an extra $60.00 over the life of a hydraulic oil change.
   / Kubota Oil...A decision! #16
Re: Kubota brand oil
Is there some reason not to use an aftermarket oil or fluid?
   / Kubota Oil...A decision! #17
Viscosity and warranty seem to be the dealer reason also filters.
Today tractors are a tad more complex than yesterday tractors,and by that I mean the old cast iron engine which 10W-40 fluid was used.
Back than if you had 3qts of Shell oil and needed one more qt you could have use Mobil if need be.
Most manuals have a section on lubricant specificatios w/guide line on what to use plus other makers w/brand names...Remember the old Fram tv ad..."You can pay me now or pay me later"...Well its true. /w3tcompact/icons/wink.gif
Thomas..NH /w3tcompact/icons/wink.gif
   / Kubota Oil...A decision! #18
Thanks for the insight!!!
Nothing better to hear it from the one who knows best---the one pulling the wrenches on them for a living./w3tcompact/icons/smile.gif
Gordon
   / Kubota Oil...A decision! #19
Snell,
After having a chat w/couple of long time Kubota techs about what fluid I should use,they agree on UDT for the protection also performance in this region on a B7100HST.
They also stated let the tractor warm up before useing for proper operations,and on sub zero days use the heater block.
Since they know more than I ever will and yet to have any problems,I shall leave well enough alone...if it broken don't mess w/it...one of my rules. /w3tcompact/icons/smile.gif
But you still have me wondering. /w3tcompact/icons/wink.gif
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A52748)
John Deere 700...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A52472)
2006 V.E...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A52577)
2005 INTERNATIONAL...
2016 Sure-Trac 20 Ton Pintle Trailer, VIN # 5JW2U2522G1121114 (A51572)
2016 Sure-Trac 20...
