NCRoadRunner
Just in case any of you out there are interested in the documentation for the Kubota 'options' we have added to ours, you can view the install directions below. If we add more, we'll add to the list. If you have one that is not here, email a copy to us, and we'll add it to the list. Please be sure to add your 2 cents about your install. One thing I can say for each of these add-ons, they are very well engineered, and are easy to install.
Lower Windshield Kit (V4315)] - this is simply an assembly process, it 'straps' onto the roll bars when you want it. We will not be using it till the weather gets cool.
Glass Windshield Kit (V4316) - If you have the top installed, you'll have to remove the 4 'U' bolts that attach the top to the roll bars, and 'pitch' it up slightly to install the windshield bracket. We were concerned that having the glass installed, since it is not easily removed, that on a hot day the windshield would diminish the airflow too much - well, it's like a wind tunnel. The air comes up over the hood, and blasts in. When you put the lower part in, there is virtually no air coming through - which will be great in the winter.... Also when driving in the rain, if you stay at lower speeds, the rain does not come in the front at all, floor it and you'll get wet! The install will take about 30 minutes.
Silver Front Guard Kit (V4325) - If you have a winch installed, you may have to remove the fairlead, or remove the 'hooks' that are on the back of the guard (they simply support it on the front rail to help hold it in place while you are installing the 4 mounting bolts). Without the winch, the install will be 10 minutes or less; add another 20 minutes if you have to remove/replace the fairlead.
Speedometer Kit (V4333) - The worst part of this install is removing the part in the dash where the speedometer goes. They suggest a holesaw, but I put a fine tooth sabre saw blade in a handle I made from a 3/4" dowel. There is a small hole at the top and bottom of the dash cutout to get you started. The documentation indicates that the speedometer is 'not compatable' with the winch, but all you have to do is add a pigtail from the speedometer 'tri-connector', the yellow with red tracer wire, and use that with the winch as the switched lead. I tried to remove the 'sender' plug without removing the air cleaner, but the retaining bolt was very tight. It was much easier after I remove/replaced the air cleaner. This install took me about 45 minutes (some screwing around time with the air-cleaner).
Rear Utility Screen Net Kit (V4350) - If you have the top installed, you'll have to remove the 2 'U' bolts that attach the top to the roll bars, and 'pitch' it up slightly to install the 3 screen brackets. The install will take about 30 minutes.
Cheers,
Henri
Cheers,
Henri
