Kubota SSQA on a LA364 loader?
   / Kubota SSQA on a LA364 loader? #42
yes, LA304 & LA364. The dealer may ask you what machine it's going on and if you mention the LA364/B2920, they'll probably have no advice on yes or no.
   / Kubota SSQA on a LA364 loader? #43
And that is the conversion from pin on to skid steer quick attach for la364 loader
   / Kubota SSQA on a LA364 loader? #47
Or is that for the 504 witch I am told is the same
Here's how I figured out that the SSQA adapter from the new (at the time) 524 loader would work on the 504 loader that is on my B3200.
I went to the Kubota site - and started looking up the bucket part numbers. When I found that the Kubota part numbers for the 54" and the 60" buckets were the same - I figured the loader spacing must be the same.
If you want to verify that the SSQA will work on your loader - that is the route I would take.
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2001 CATERPILLAR 621F MOTOR SCRAPER (A60429)
2001 CATERPILLAR...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
