Kubota tractor front loader hydraulic issues
   / Kubota tractor front loader hydraulic issues #1
rcbor187
Cali
Kubota RTV 900
So I came back last monday to find the tractor in need of repair or diagnosis. When switching from forks to bucket the two hydraulic cylindars seem to be not in sync with each other. It almost seems like something is bent. I do notice that when Im standing and looking at the front , comparing the two hydraulic shafts, one is extended farther out then the other.
I spoke to the dealer and they said I could try draining the entire hydraulic system, in hopes to sync the two front cylindars.
This seems like an awful lot of work.
Was hoping someone with more experience can chime in and let me know what they think.
Thanks
the issue is with the quick connect feature.
I have reposted this in kubota tractor area.
   / Kubota tractor front loader hydraulic issues #4
Some dealers don't have any common sense. Draining hyd oil won't get bucket cylinders into synchronization but gently placing quick tach bracket(if applicable) against something solid & putting a little pressure on the cyl that is most extended one can easily even the rod length of both cylinders.
   / Kubota tractor front loader hydraulic issues #5
In the same vein if you get square with an immovable object with your quick attach then curl it down so that the side with cylinder more extended is contacting it solidly then curl it more till the other side makes contact you should be squared up again.
We are saying the same thing just in different ways.:thumbsup:
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
New Wolverine Mini Skidloader Post Hole Digger (A50775)
New Wolverine Mini...
2002 PITTS 102" X 35' LOWBOY TRAILER (A51406)
2002 PITTS 102" X...
2007 FORD F150 XL EXT CAB TRUCK (A51406)
2007 FORD F150 XL...
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
2020 Kinze 3505 High Speed 6/11 Planter (A55302)
2020 Kinze 3505...
